A pair of these with reducers to 2-1/2" will do wonders fitted in your tailpipes. https://www.summitracing.com/search/...ype/resonators The factory did these with automatics 68-69. |
Yeah I do feel like I was upsold but I had two people local tell me that’s what they were running and I always like the sound of their cars so here we are. They are clamped on so it’s not the end of the world but they will get changed if they are too loud with the interior in. It’s just so hard to tell inside cause everything rattles.
I have used Autolite 3924s in my E heads.
The Late Model circle track car I had for a few years had dual MSD 6 boxes so during a race if one crapped out your could just turn a switch and use the other one.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I don’t mean to say I don’t like the sound or it’s too loud it’s just that every damn thing in the car rattles right now so I can’t tell how they will be in the end. They are now quiet enough that I can hear the tic inside the car that o was only able to hear standing at the engine with the Black Widows.
Also you guys got to remember I am in a tiny town with a small exhaust shop. I can’t drive it 50 miles to another place to get it done and they won’t let you bring parts. You get what they have or you go somewhere else.
None of these are options?
Getting all the rattles etc out is something that takes effort (and cost) during assembly. I made a point of it when doing the Judge & 442 project, and will do the same on the 'bird project. It's well worth it though, makes an incredible difference. Doors and dash are focus areas. .
I was mistaken, I thought the 2nd closest one was where I got my exhaust. It’s not, the shop that did mine only does exhaust period. The rest of those are general service shops that might slap on a muffler.
I have sound deadener on the floor and plan on putting it on the doors. Where else should I put it?
Floor and doors are the biggie, but you should try to get as much as possible on the interior side of the firewall too. That's not always that easy, just try to do as much as possible. Since you have a dash 'substructure', cut strips and stripe as much as you can of that. On the gauge insert, just try to make sure there's not a lot of loose wire and stuff. You can zip tie loose items/bundles, just don't pull the zip ties tight, leave them a little loose. Doors, make sure all the lock & latch rods have the 'sock' on them, or use some other method to reduce rattle, like maybe pieces of vacuum tube or something. Those rods slide, so make sure they still move freely after. You can use short piece at strategic locations, you don't have to cover the whole rod(s). The rear seat inner panels make a difference too, try to get some on those areas. You can cut strips and lay them on the inner wheel well too. I only go from the highest point forward to the floor, so you can't see it from the trunk. You can do the back part if you don't care about seeing it in the trunk. I do the trunk floor, which for me gets covered with the trunk mat. Trunk floor helps reduce any drone from back there. The rear package tray can be covered some, and helps. On the trunk divider, I used DynaLiner (thermal barrier) on the trunk facing side, it helps control the metal bracing resonance, and og course, thermal intrusion from the trunk. I used DynaLiner on the doors and floor too. I used the thinner stuff on the door to ensure the door panels fit good, and thicker on the floor. Used a medium one on the firewall where I could, and on the package tray top. I stripped off all the glued on matting from the carpet, trunk divider, and package tray so that would all fit better. The sticky mat controls much of the resonating sound at 65-70% coverage, and the gain between that and 100% has little return. So don't kill yourself trying to get full coverage. The important part is to make sure it's as stuck as possible to the panels. (I do a quick wipe with acetone before applying). I didn't do the roof in the A-bodies, since the sticky mat can droop from the roof getting hot. They make lightweight foil stuff, but I didn't bother. Your call there. You can do the underside of the trunk lid if you want, but I didn't bother for the same reasons I didn't do the inside of the roof. Cut out holes for the hardware, like seat & belt bolts and interior panel clips, it will save frustrations when you go to install stuff. You can check people's build threads on how others have done it, or search YouTube for tips. Aside from other mods I've done to cars, sound & thermal control is one of the most rewarding things I've ever done.
| The Following 3 Users Say Thank You to HWYSTR455 For This Useful Post: | ||
Our cars do not come with them but one of the main areas for sound suppression is between the dash and firewall - hush panels they are called.
You'd be miles ahead as far as noise goes by losing the 3" exhaust and huge tips and moving to a sensible 2.5" system with Walker Turbo mufflers. Nice tone, no drone, can talk inside the car. I personally have no use for 3" exhaust on any street driven car.
Jeff |
| The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
3” all the way to some 3” to 2-1/2” reducers at the 2-1/2” mufflers and tailpipes would work nicely, once the exhaust gasses have reached the mufflers the gasses have cooled and contracted.
Since you already have 3” up to the mufflers already I’m assuming. I sold my 3” system and went for 2-1/2” on my LS3 Tempest for less noise and better ground clearance since it’s lowered a couple inches. Even bought exhaust manifolds to replace the headers, just easier to work around and simpler as well as much better ground clearance.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 2 Users Say Thank You to b-man For This Useful Post: | ||
Jeff |
| The Following 2 Users Say Thank You to geeteeohguy For This Useful Post: | ||
Now that I am driving it I’m pretty pleased with it. I can hear the radio now and will be fine I think when I put the interior in
| The Following 2 Users Say Thank You to 64speed For This Useful Post: | ||
Glad to hear it…mean something turned out right finally.
| The Following 2 Users Say Thank You to Gach For This Useful Post: | ||
That’s all that matters!
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
i have a full 3" with x pipe and walker super turbos for years now and it's quiet
| The Following User Says Thank You to imposter For This Useful Post: | ||
I’ve got almost everything worked out of any major concern. Except I can’t get one lifter to quiet ticking and I’m pretty sure it’s the one that backed off. I unlocked it and tightened it an 1/8 of a turn but I am afraid to go any further. It did get quieter though.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 08-20-2023 at 09:28 PM. |
