Old 11-06-2025, 09:40 PM
moneypit's Avatar
moneypit moneypit is offline
Busy day for me, drive belts and speedo cable lube on the GTO.
Pulled the headliner on the Firehawk, I will drop it off with the upholstery guy tomorrow..
Drove the 37 to a Ribs & Rides show in a nearby town.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
The Following 3 Users Say Thank You to moneypit For This Useful Post:
Old 11-06-2025, 10:02 PM
Shiny Shiny is offline
Removed rear valance to start on bumper and taillight replacement, which will follow body work attempt on some quarter panel carnage.
The valance is bent a LOT less than my front was, which is welcome news. Worst of it is a dent someone decided was needed to install some Big Gulp exhaust tips that are destined for the recycle bin.
I also suffered a failed attempt to remove the rear springs, but I'm OK with that.
ID:	660173   Click image for larger version
The Following 2 Users Say Thank You to Shiny For This Useful Post:
Old 11-06-2025, 11:32 PM
Took my 1966 VW pickup to Walmart to get my new tires mounted and balanced today.
A couple months ago I swapped the 16x8-1/2” 1984 Corvette wheels I had been running on my pickup since 1988 for a set of Weld Draglites, 15x5” and 15x8” shod with 185/55 and 205/55 Yokohama tires. The ride has improved and it’s much easier to steer now.
I almost put the Draglites on the Le Mans convertible but thought the VW truck would be better suited. The width and backspacing just happened to be right, kinda like when I shoehorned the wide Corvette wheels on it back in the day.
Also recently polished up a set of Centerlines for my 1956 VW panel bus, it’s getting all new suspension and a lowering job. It will also have 2 sets of wheels to change the look, a set of white powder coated original 15x4-1/2” bus wheels for when I’m tired of the Centerlines.
ID:	660183   Click image for larger version
ID:	660184   Click image for larger version
ID:	660185   Click image for larger version
ID:	660186   Click image for larger version
The Following 7 Users Say Thank You to b-man For This Useful Post:
Old 11-07-2025, 08:48 AM
Half-Inch Stud's Avatar
Brushed a bunch of Rods and Pistons, after sitting in Gasoline a week. Need 421+030 so need 428 STD.
FB MKTplace revealed a fella nearby with a couple 455 blocks for sale. I go hmmmm. Maybe visit his garage this afternoon.
The Following 3 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 11-15-2025, 07:38 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Looks like a different car. Cool car.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 11-07-2025, 10:44 AM
PAUL K's Avatar
PAUL K PAUL K is offline
I'm putting together a 74 TA and wanting to maintain that old school hot rod look from the 80's. I just finished up mock assembling the bracketry for the supercharged Pontiac engine I'll be using. I also got to clean out my misc bracket bin. I started with a big block Ford blower hub and pulley. Used a 70 Firebird PS pump and bracket, 1967 timing cover, a vintage polished alternator. One of the cars had come with a hacked up, poorly polished alternator that made a noise exactly like a rock crusher transmission, I think I found a good home for it. It will compliment the 70's quality polish on the blower. A 69 F-body alternator bracket was used for the top mount, a 71-79 AC water pump pulley and a Toyota Forerunner V-belt.... Once cleaned up and painted it'll have "that look".
Go fast, see Elvis!
The Following 8 Users Say Thank You to PAUL K For This Useful Post:
Old 11-07-2025, 07:38 PM
BB70's Avatar
BB70 BB70 is offline
Had to pull Mr Glitter out due to a rocker arm losing half its needle bearings a couple weeks ago. Found all but 4 of 30. Cleaning up and recleaning. It could have been worse.
ID:	660223   Click image for larger version
Old 11-07-2025, 08:00 PM
PAUL K's Avatar
That's always a bummer! Hopefully you can make some upgrades and turn a negative into a positive
Go fast, see Elvis!
Old 11-17-2025, 10:26 AM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
We had more nice weather on Saturday, so I cleaned all four vehicles, then took the LeMans for a cruise. Stopped downtown for a photo opp.
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 3 Users Say Thank You to 73_Lemans_350 For This Useful Post:
Old 11-17-2025, 11:24 AM
srmmmm's Avatar
srmmmm srmmmm is offline
Had beautiful weather in DFW yesterday and I finally felt confident enough in the carb settings to give the wife some wheel time. She enjoyed almost 100 miles of mixed city and highway driving, but commented that she was only going 30 to 35 sometimes so I had to point out that the tach and the speedo are on opposite sides from her BMW.
Everything went smooth until it was time to turn the headlights on and she had to turn the high beams off. The left foot needed a little training. But glad she enjoyed it and got her comfort level back with some old school driving.
The Following 7 Users Say Thank You to srmmmm For This Useful Post:
Old 11-18-2025, 03:22 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
That’s awesome that she felt confident in driving the Bird! My wife has said once or twice she’s not sure if she trusts herself to drive ours now when I finish it… knows it will be a handful. And it’s only been 23 years, has a 4spd now!
We just had that discussion on the dimmer switch as I was installing the carpet. She’d forgotten about that!
The Following User Says Thank You to 7t4mula For This Useful Post:
Old 11-07-2025, 09:05 PM
carcrazy carcrazy is offline
After a lengthy search in the garage, finally found my new lug nuts for the Rally wheels!
Old 11-08-2025, 07:01 PM
Drove the 71 Catalina Enforcer for the 1st time in 10 years, the shop scheduled to do the body and paint work is running about 6 months behind, so I had to bring it home after all the mechanical work was done. It is the farthest I have ever driven the car, about 65 miles about 1 1/2 hours on the surface streets. Had the blower motor quit about 10 minutes into the trip, so I had some cold feet (only about 45F in Detroit today) Then about 1/3 of the way home the temp light came on about 15 seconds before steam started coming out of the hood as I pulled into a Fast food restaurant parking lot. At first I thought it may have been the heater core, but after all the steam cleared I could not find a leak, and decided the thermostat must have stuck closed. So after a quick trip to a nearby auto parts store for some coolant, rags, funnel, and RTV. I removed the thermostat for the rest of the trip, Made it home after that safe and sound. The car sure does drive and handle well for a 50 year old boat!
Happy ending! No Tow needed!
Name:	Enforcer passing anouther excruiser on Grossbeck 08Nov25.jpg
ID:	660291   Click image for larger version
Name:	The heat is hear Wendy's parking lot 8 mile and Grossbeck.jpg
ID:	660292   Click image for larger version
Name:	Enforcer on 8 Mile 08NOV25.jpg
ID:	660293   Click image for larger version
Name:	Enforcer Home 08NOV25.jpg
The Following 11 Users Say Thank You to camerjeff For This Useful Post:
Old 11-08-2025, 07:34 PM
SD455DJ SD455DJ is offline
Wow! That was quite the adventure! Sorry to hear about the overheating...maybe the cold weather helped mitigate it a bit. First drives after 10 years in old cars exposes the lurking gremlins. Glad you were able to repair on the road and make it back home before the crappy weather hits Michigan tomorrow! Looking good!
Dennis
Old 11-09-2025, 06:01 PM
67drake's Avatar
67drake 67drake is offline
The prodigal Goat is back.
My ‘55 is in the upholstery shop for the winter, so told my son he could store his ‘71 in the heated garage for the winter, seeing as how I have a space open. Probably for the best, as I’m sure I would find another project to fill the empty space!
‘55 Catalina
The Following 5 Users Say Thank You to 67drake For This Useful Post:
Old 11-09-2025, 08:55 PM
Drag Star Le Mans's Avatar
Went for a short ride and hit the shift light a few times.
DragStarLeMans
The Following 11 Users Say Thank You to Drag Star Le Mans For This Useful Post:
Old 11-10-2025, 11:31 AM
Tempest's Avatar
Tempest Tempest is offline
Good looking wagon
Old 11-12-2025, 01:18 PM
Dug the '67 Gp out of storage yesterday for some much needed cleaning and maintenance... And yes... I need to clean up my garage too..
The Following 4 Users Say Thank You to 71GP76TA For This Useful Post:
Old 11-12-2025, 04:34 PM
it's cleaner than mine!! LOL
After pics of the GP would be nice
71 LeMans Sport Convertible
04 Pulse Red GTO A4
10 GMC Sierra 1500
Old 11-15-2025, 12:12 AM
BB70's Avatar
Had success installing my new cam bearings, I was pretty intimidated about it for a couple days before hand tho. Couldn't believe the cam went in and spun great. Got one for the win column finally.
Went ahead and laid a head on it to check pushrod length with the new rockers. All looked ok there, but I really want to upgrade to 3/8 pr but I think that will have to wait. I have .116 5/16 but think it needs fatter ones.
John
ID:	660707   Click image for larger version
ID:	660711   Click image for larger version
The Following 5 Users Say Thank You to BB70 For This Useful Post:
