Old 07-03-2019, 01:14 PM
cgeise's Avatar
cgeise cgeise is offline
On the shock issue -- My turbo gar had Strange -- and as it got faster we had issues -- long story short -- swapped to custom configured Penske and Bazinga -- fixed ir
  #1642
Old 07-03-2019, 04:01 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by cgeise View Post
You need to pull timing out on the t-brake - it helps spool faster -- Tell LIL Jack to -- stay in his own lane --
Damn silly turbo cars!
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #1643
Old 07-03-2019, 04:38 PM
cgeise's Avatar
lol yea they are a beast of there own ---- btw that popping noise you hear them make at the starting line is because some applications pull A LOT of timing to get the thing spooled up -- more so on a stick car but still need some on an automatic -- live long and prosper
  #1644
Old 07-23-2019, 09:58 PM
67'7F6'Bird's Avatar
OUCH!
Name:	Raven Apart.jpg
ID:	516266   Click image for larger version
  #1645
Old 07-23-2019, 10:11 PM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
Oh no
Gonna have it back together for Norwalk?
  #1646
Old 07-23-2019, 10:12 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by 67'7F6'Bird View Post
OUCH!
Had an issue with the intake valve on #2.
ID:	516273   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1647
Old 07-23-2019, 10:18 PM
chiefbigb chiefbigb is offline
That sucks big time. Could have been much worse though
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
  #1648
Old 07-23-2019, 10:28 PM
RAIV-Z's Avatar
Originally Posted by 535 tall deck View Post
Oh no
It's going back together, Kingsley Machine turned the head around in under a week, Don from DCI Motorsports had guides, and other needed valve train parts delivered in 2 days. Joe Bass supplied a set of T&D steel rockers when T&D said it would take 3-4 weeks to get a few replacements. T&D then ended up delivering the replacements and a few spares in under a week.
We're looking much better right now.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1649
Old 07-23-2019, 10:30 PM
Scott Roberts Scott Roberts is offline
Did you find the root cause?
  #1650
Old 07-23-2019, 10:39 PM
RAIV-Z's Avatar
I'd say currently inconclusive.
Machine shop was leaning towards valve failure. Victory performance is interested in taking a look at the valve train.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1651
Old 07-23-2019, 11:43 PM
Is the top of the piston beat up? The first pick it looks like something was bouncing around and hitting the valve... the other one well...it was ****ed and folded in half...
  #1652
Old 07-24-2019, 02:00 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Could have been much worse, if the valve head hadn't "hid" in the port. When I had an intake valve separate like that (my very first blown iron Pontiac) the valve head apparently didn't try to "hide"- broke a whole corner off the block!
I sure hope you make it to Norwalk. I've been waiting to see it run.
  #1653
Old 07-24-2019, 06:46 AM
slowbird's Avatar
slowbird slowbird is offline
How does the keeper, retainer, spring, rocker arm, pushrod, lifter and cam lobe look? Victory valves are pretty high quality, i wouldn't think the head would pop off like that unless it was the wrong valve for the application. I would definitely look things over closely to insure something else didn't cause it so it won't happen again.
  #1654
Old 07-24-2019, 07:47 AM
AG's Avatar
AG AG is offline
Lucky the valve head didn't dance around the chamber/cylinder.
  #1655
Old 07-24-2019, 10:01 PM
RAIV-Z's Avatar
The Raven just fired back up, too late to pull it outside. We'll heat cycle it tomorrow and re-torque head, re-adjust valve and check everything over.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1656
Old 07-25-2019, 01:32 AM
charlie66's Avatar
What valves are they ? Are they made from inconel?
Good luck with the fix....
My Half AN Injun.....
  #1657
Old 07-25-2019, 02:22 AM
Wow- quick repairs! Glad to hear it fired up okay. Hope you make it to Norwalk.
  #1658
Old 07-25-2019, 03:48 PM
The "RAVEN" will see you all in Norwalk.
Name:	Ed Raven.jpg
ID:	516451   Click image for larger version
ID:	516452   Click image for larger version
Name:	Raven Adjusting Valves.jpg
ID:	516453   Click image for larger version
Name:	Raven front engine Shot.jpg
  #1659
Old 07-25-2019, 03:51 PM
mysticmissle's Avatar
https://www.youtube.com/watch?v=dd1MMkdUW6c my three best guys working on it
  #1660
Old 07-25-2019, 04:17 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Did you replace all of the valves?
