#1701
Right Lane
#1702
Congratulations. Looks like you added a little more power, but it also looks like you are starting to get a handle on the 60 foot times also.
Stan
#1703
#1704
Are you leaving off-idle?
The 60 foot looks slow but it's coming on stronger later. Probably making boost gradually? I would say it's got a lot more in it?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
#1705
We're getting boost building on the t-brake under control, finally leaving at above 6lb of boost. Increasing overall boost to ~28lb.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1706
The 1.2x 60's will start to get better, getting used to the additional launch boost will take a few more passes. This was the first one. It's was a bit of a change going from 6lb to 10.7lb.
#1707
I'd love to have that time slip, since I'm certified to only 7.50 with my mild steel chassis. Congratulations! Don't stop there. ![]() Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#1708
so what boost controller are you using ???
#1709
It's part of the Holley Dominator EFI ECU.
#1710
What "should" the 60ft be?
#1711
I’m thinking with the boost he’s running now he’s pretty darn close for a turbo car!
GTO George |
#1712
(mine in my slow dragster is 1.09-1.15) I suppose the turbos may be 'soft' on launch, but don't see why it should be. The guys that are hampered by small tires would probably have slower 60' times.
#1713
As for small tires having slow 60’ times. Most decent 275 tired cars will go in the 1.10 range on decent tracks. A good one on a radial prepped track will go low 1.00s. |
#1714
Thanks for the small tire info.
My sentence should have been 'could probably' and not 'would probably'. I have no info on their et slips to check with. And I agree the learning curve is going the right way. Will be lots faster I believe.
#1715
1.215 60 foot. https://www.youtube.com/watch?v=uplki1u8Gdk
#1716
Looked good!
What's the rev limiter RPM on while on starting line?
#1717
On RPM 4800 Off RPM 4770
#1718
ok Im not sure how that one sets up but on the one I used it worked best by ramping up in small quick steps --all in by a second or less
#1719
Were you adding/removing fuel and/or Timing?
#1720
the boost controller was adding pressure to the back side of the waist gate in small increasing amounts very quickly -- the fuel pressure regulator added fuel based on boost pressure ie boost referenced and if I remember right timing was at about 25 degrees over 12-15 lb boost . Boost controller setup was 12lb springs in the waste gates and then every lb of c02 on the back side of the gate increased boost by aprox a lb -- data recorder will tell you exactly how much.
