Old 08-09-2023, 11:57 PM
64speed's Avatar
64speed 64speed is offline
Originally Posted by NeighborsComplaint View Post
Glad to hear you got it rolling again. I’ m anxious to here how you like the new combo but take your time and make sure you have the timing dialed in and some easy break-in miles under your belt .
To be honest just in the driving tonight I can’t tell enough of a difference to justify the cost of buying new roller lifters etc. I really like the cam. Thank GACH for his recommendation.
  #1702
Old 08-10-2023, 12:37 AM
Gach's Avatar
Gach Gach is offline
Your welcome, I knew you’d like it. Easy 500 hp for your combo
The Following User Says Thank You to Gach For This Useful Post:
  #1703
Old 08-10-2023, 05:51 AM
64speed's Avatar
I have a slight and I mean slight leak at the top of the timing cover on the passenger side where the timing cover meets the block right by the bolt hole. I had to take the bolt out to put the brackets on. Do I need thread sealer or what?
  #1704
Old 08-10-2023, 05:54 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
SO glad to hear that it's running again! Enjoy!
  #1705
Old 08-10-2023, 06:33 AM
steve25 steve25 is offline
Well all the holes related to holding on the timing are, or should be blind unless they where at some point repaired and drilled too deep.
To be safe just put some sealer on it and then re-tighten down all the 4 bolts and two stud nuts that hold the cover on.
  #1706
Old 08-10-2023, 07:26 AM
64speed's Avatar
Little tinkering left but I think it’s actually better for me than the roller. It’s a long way to the top if you wanna rock and roll ��
The Following User Says Thank You to 64speed For This Useful Post:
  #1707
Old 08-10-2023, 02:22 PM
NeighborsComplaint's Avatar
Yep, I told you it would run just fine and to forget the "magic cam" Paul spec'd for you. It's going to be easier on the valve train and much better around town.
Triple Black 1971 GTO
  #1708
Old 08-10-2023, 02:49 PM
64speed's Avatar
So the leak resolved itself so I won’t look a gift horse in the mouth. Clutch is sticky coming up which I assume is air still in the line. It was a pain getting any pedal at all and then over night it got worse. So I’m thinking air moved around????
  #1709
Old 08-10-2023, 02:53 PM
64speed's Avatar
https://youtube.com/shorts/tFebY_Tq3YE?feature=share
The Following 2 Users Say Thank You to 64speed For This Useful Post:
  #1710
Old 08-10-2023, 03:02 PM
Gach's Avatar
Whoo that sounds good, god thats a gorgeous car.
The Following 2 Users Say Thank You to Gach For This Useful Post:
  #1711
Old 08-10-2023, 03:39 PM
mysticmissle's Avatar
Gach is right thats a beauty, car is excellent love the post coupes myself. what dash is that and also what sound deadener did you use on the floor?
  #1712
Old 08-10-2023, 03:40 PM
JSchmitz's Avatar
Looks and sounds great!
  #1713
Old 08-10-2023, 03:46 PM
64speed's Avatar
Dakota Digital RTX. That is Amazon brand sound deadener. 50 bucks for enough to do the whole damn car
  #1714
Old 08-10-2023, 04:30 PM
Sweet car! Sounds just as rowdy at idle as it did with the roller cam. You're going to enjoy that car.
  #1715
Old 08-10-2023, 04:38 PM
64speed's Avatar
It’s nasty. Actually thinking of quieter mufflers. I am a music lover and I can’t hear anything in the car
  #1716
Old 08-10-2023, 04:39 PM
64speed's Avatar
I think my thermostat is sticking. It is a 180 but it’s going to 210 then coming down and going back again and on and on
  #1717
Old 08-10-2023, 04:49 PM
grivera's Avatar
grivera grivera is offline
Don’t change the mufflers till you get carpet and a full interior in there as it will muffle the sound a bit.
Is the upper radiator hose hot at 180 (test with infrared gun)? Also, not sure if you’ve done so but I check every thermostat in a pot of water with a thermometer before install - so far above 50% don’t open at advertised rating - more like 10-15 degrees above it.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
  #1718
Old 08-10-2023, 05:14 PM
I’m glad to see things have finally come together.
Dr. Thomas Sowell
  #1719
Old 08-10-2023, 06:11 PM
Gach's Avatar
What I can’t hear you…LOL trust me I know the feeling.
  #1720
Old 08-10-2023, 06:14 PM
Gach's Avatar
Its a new start up, might just be working air out. Hopefully it will stabilize.
