#1741
16 percent slip is Not good -- you know that -- time to fix that convertor -- I was seeing 8k on mine and never saw an engine issue, have you considered a 4.10 rear gear??? it will tighten up that convertor.
#1742
With 8 quarts of John Deere Hygard, 3rd gear slip is ~5% @ 7740RPM
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1743
We has a parts failure October 13th, the transmission case cracked during the run. The internals were in good shape so we replaced any worn parts and the case.
#1744
Hard wheelie?
New tranny looks good.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
#1745
Just in time to come run World Cup Import vs Domestic with Bad69bird and and I
6.98 @ 199mph 4.53 @ 164mph |
#1746
Can't make it this year... Looking forward to you 2 kicking some import A$$.
#1747
A little pre-Christmas update on the Raven’s winter refresh. The engine has been disassembled and delivered to
Kingsley Automotive Machine . The IAII iron block and Callies Performance Products Ultra rods checked out good. Ross pistons, pins and rod bolts as well as the cam shaft will need to be replaced. The damper hub cracked along the keyway. Innovators West, Inc. West is upgrading the 1 7/8th hub to 2 1/16th and also adding a second keyway. The camshaft keyway is also starting to crack. I’m updating the timing belt setup from the BOP gen1 to gen4 version. The bottom timing sprocket will be modified to accept the larger damper and second keyway. The 9.5 PTC - Performance Torque Converters was sent in to get checked out to make sure there was no internal damage when the transmission case broke. The converter will also be tightened up a bit.
#1748
Ed,
Since you have to replace the cam will you be making any changes in timing based on your testing or stay with the same profiles? Stan
#1749
I had the same issues cracking damper hubs --running the dry sump and the mech fuel pump was hard on it also had to do the timing belt upgrade on one of the motors -- did the tranny have a solid mount -- or urethane ??
#1750
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
#1751
The trans mount is urethane.
#1752
Current cam card attached.
#1753
a couple they were TCI and single
#1754
on the cam seems a bit small if I remember right
#1755
#1756
#1757
Off to the chassis shop for a few winter mods while the engine is refreshed.
#1758
Quoted by ED Page
Raven winter update: 3/16th partial steel midplate replaced with ¼ aluminum full plate Hall's Custom Performance Torque Converters torque converter checked out and tightened up. Innovators West, Inc. damper internals checked out and larger hub machined and double keyed BOP Performance belt drive upgraded to a GEN-IV (Previous was a GEN-III) DEI Header wrap being replaced with Summit Volcano Wrap Fuel Injector Development 275lb injectors cleaned and reflowed ARP Automotive mains being replaced with a new set. Crower Cams & Equipment Co.Crower Billet 4.5 being replaced with a 4.25 ATI flexplate being replaced with a Meziere Composite distributor gear swapped out for a bronze Brian Hedrick Pistons/Rings and potentially rods will be replaced (TBD) Cam shaft will be replaced Also considering some DCI Motorsports head work. On a positive note, I have 2 oil filters and a few sets of spark plugs left from last year. More Photos in RAVEN RACING - Facebook Group. BELOW: https://www.facebook.com/groups/220092308823847/ |
#1759
Raven Winter Update #2
3/16th partial steel midplate replaced with ¼ aluminum full plate Hall's Custom Done Performance Torque Converters torque converter checked out and tightened up. Done Innovators West, Inc. damper internals checked out and larger hub machined and double keyed Done BOP Performance belt drive upgraded to a GEN-IV (Previous was a GEN-III) Acquired DEI Header wrap being replaced with Summit Volcano Wrap Acquired Fuel Injector Development 275lb injectors cleaned and reflowed Done ARP Automotive main studs being replaced with a new set. In-transit Crower Cams & Equipment Co .Crower Billet 4.5 being replaced with a 4.25 Acquired Moldex 4.25 ATI flexplate being replaced with a Meziere Acquired Composite distributor gear swapped out for a bronze Brian Hedrick Acquired Cam shaft will be replaced Acquired Next up…. Pistons/Rings and potentially rods will be replaced 4.360 pistons Aluminum rods Wastegates dumps relocated so we won’t melt the spoiler(s) again
#1760
Why did you switch to a shorter stroke? For durability or will it make more power with the shorter stroke?
