Old 03-25-2026, 05:53 PM
Originally Posted by form74 View Post
,,,Also swapped out the lock and gas cap with a stock cap. The last one was a pain in the butt.
Given the rising price of gas I would not throw that locking cap away...
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
Old 03-26-2026, 03:43 PM
tempest1964's Avatar
Worked on setting up my ring and pinion. I think it’s pretty close. Thoughts? Picture on left is drive. Right is coast.
ID:	667014   Click image for larger version
Old 03-26-2026, 05:20 PM
67drake's Avatar
67drake 67drake is online now
Run it! Looks great
‘55 Catalina
Old 03-26-2026, 04:15 PM
KS circutguy's Avatar
Looks good.
The Following User Says Thank You to KS circutguy For This Useful Post:
Old 03-26-2026, 06:51 PM
Added a separate power and ground from the trunk battery to the ECM.
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
Old 03-26-2026, 08:01 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
New front door panels and armrests. A couple other bits and pieces too.
ID:	667034   Click image for larger version
ID:	667035   Click image for larger version
ID:	667036   Click image for larger version
The Following 3 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 03-26-2026, 10:45 PM
SRGN SRGN is offline
I did get her cleaned up this weekend. Had to add a picture of course.
The Following 5 Users Say Thank You to SRGN For This Useful Post:
Old 03-26-2026, 10:35 PM
Today, just scoured the internet looking for odds and ends for mine. Waiting on parts so I can add AC before it gets hot out.
The Following 3 Users Say Thank You to SRGN For This Useful Post:
Old 03-27-2026, 06:39 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Looking forward to nice cool AC as well! I’m installing my Vintage Air condenser and dryer today actually. So far so good. Made sure to wrap unit in cardboard to not scratch or dent!
Note to self… read entire directions before proceeding. Several steps would’ve been much easier to do in different order. Like trimming core support to clear lines, after condenser is already bolted in! LOL
ID:	667093   Click image for larger version
ID:	667092   Click image for larger version
ID:	667094   Click image for larger version
The Following 5 Users Say Thank You to 7t4mula For This Useful Post:
Old 03-28-2026, 06:46 AM
Looking good, the Vintage Air kits go in pretty nicely. They work well too. Unfortunately nobody makes a kit for mine, so I'm just going to put an add on unit under the dash. I will probably end up with a lot of leftover parts after trial and error.
The Following 2 Users Say Thank You to SRGN For This Useful Post:
Old 03-28-2026, 04:58 PM
Almost forgot, post some pics of that Bird! I have a soft spot for green second gens.
The Following User Says Thank You to SRGN For This Useful Post:
Old 03-28-2026, 05:02 PM
Got tired of not being able to see the speedometer at night, put led bulbs in and it's great now. "Ice blue" is the name of the color, has a good appearance. The darker blue was too much.
Old 04-07-2026, 04:48 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Checked progress on the bird at The House of Hotrods and things are looking better. New reproduction RAIV intake from OER had much better fitment, but one of the coolant passage sensor holes was tapped to deep and wouldn't seal. With some research we determined that the TCS sensor wasn't needed to make the engine harness work, so a nice aluminum NPT took care of the situation. All the HVAC controls work properly with an outside vacuum source, but vacuum is not getting past the canister to the switch when running off the engine. Either a bad canister or a pinched hose.
The major culprit are the front seat tracks. So we've now learned that the 1970 seat tracks are one-year only and so is the floorpan. The bottom section of 1969 tracks aren't long enough to match the holes in the floor, and the bottom section of the 1971-74 tracks are too low and the adjusters hit the floor. So they're going to take apart my originals and the new 1969 tracks and reassemble the new uppers with their bearing cages with my original lowers. I'm glad I'm not doing that one.
All should be well though to get the car into the Arlington car show on June 6th.
The Following 3 Users Say Thank You to srmmmm For This Useful Post:
Old 03-28-2026, 06:43 PM
7t4mula's Avatar
Yup, sorry I’ve been so busy with family stuff so way overdue. Took this the other day when my new double pumper carb and air cleaner arrived!
I’ll try to bring my project build post up to date soon!
The Following 4 Users Say Thank You to 7t4mula For This Useful Post:
Old 03-29-2026, 08:35 AM
Longs's Avatar
Longs Longs is offline
Another photo of Vinton & Larsen. Appears that the address was 830 Northeast Highway 99W, Mcminnville OR 97128. Down a rabbit hole!
The Following 3 Users Say Thank You to Longs For This Useful Post:
Old 03-29-2026, 09:09 AM
TommyGunn's Avatar
TommyGunn TommyGunn is offline
99W and 99E were the main North/South routes through Oregon before I-5. W designation = west of the Willamette river,E designation = east of the Willamette.
Old 03-29-2026, 01:32 PM
400 4spd.'s Avatar
I dug out my N.O.S. skins and I'll be doing those before diving into the quarter and floor replacements.
Name:	67 skins.jpg
The Following 2 Users Say Thank You to 400 4spd. For This Useful Post:
Old 03-29-2026, 11:07 PM
carcrazy carcrazy is offline
Got the new billet flywheel and clutch installed on my 62, 11b engine (now 460 cu inches).
The Following 3 Users Say Thank You to carcrazy For This Useful Post:
Old 03-31-2026, 10:05 AM
67drake's Avatar
Well, don’t think I’ve mentioned it here, but was diagnosed with prostate cancer back in the fall. After many Dr. appointments on how to proceed, I decided to have it removed altogether, instead of radiation and hormone therapy. First day back home and doing fine. Too much on my plate for permanent naps right now.
My ‘55 still is in the upholstery shop, and when they removed the carpet, the rubber on the gas pedal pretty much fell apart. I found a nice one on Facebook, and it was waiting for me when I got home last night. Looks like it will clean up almost perfect, except for minor scuffing. It always amazes me when fellow Pontiac owners go out of their way to give great prices, or even give stuff away to fellow enthusiasts to dig up parts they need.
ID:	667303   Click image for larger version
‘55 Catalina
The Following 10 Users Say Thank You to 67drake For This Useful Post:
Old 03-31-2026, 01:56 PM
Shiny Shiny is online now
Originally Posted by 67drake View Post
... First day back home and doing fine. Too much on my plate for permanent naps right now. ....
Glad to hear. Take care of yourself.
