Old 02-14-2020, 10:17 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by Scott Stoneburg View Post
Why did you switch to a shorter stroke? For durability or will it make more power with the shorter stroke?
Less stress on internal parts, with more RPM. I don't think we were at the limit of power with the 4.5 stroke yet, but we were out of RPM. The majority of current big power power boosted Pontiac are in the 480 to 500cid range.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1762
Old 02-14-2020, 10:27 PM
GTOGEORGE's Avatar
Be a leader not a follower!
GTO George
  #1763
Old 02-14-2020, 10:50 PM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
How high do you spin it?
  #1764
Old 02-14-2020, 11:06 PM
Stan Weiss's Avatar
GTO George
What stroke is in Tommy Youmans engine?
Stan
Pontiac Pump Gas List
  #1765
Old 02-14-2020, 11:50 PM
GTOGEORGE's Avatar
Stan
Don’t know.........why?
GTO George
  #1766
Old 02-14-2020, 11:59 PM
cgeise's Avatar
cgeise cgeise is offline
I was running over 8k with 4.5 crank -- just fyi
The Following 2 Users Say Thank You to cgeise For This Useful Post:
  #1767
Old 02-15-2020, 12:09 AM
George how how do you twist yours up?
  #1768
Old 02-15-2020, 12:20 AM
GTOGEORGE's Avatar
Not very......I’ve had it 7,200 rpm but with my fuel situation anything over 6,800 is a waste. I wonder the stroke of those 900+ cubed No Prep and Pro Mod engines!
GTO George
  #1769
Old 02-15-2020, 12:36 AM
Stan Weiss's Avatar
Latest NKRA rule book I have is 2017. The supercharged and turbocharged Pro Mod engine have a max size of 526 ci Turbocharged and supercharged entries are limited to a maximum bore center of 4.800.
Stan
  #1770
Old 02-15-2020, 07:26 AM
RAIV-Z's Avatar
GTO George
I'm trying George, but it's not cost effective to reinvent the wheel. We will all go faster if we learn from one and other.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1771
Old 02-15-2020, 07:29 AM
RAIV-Z's Avatar
Stan
Tommy is running a 505cid engine, 4.25 stroke.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1772
Old 02-15-2020, 07:31 AM
RAIV-Z's Avatar
Soft rev limit was 7800, hard 7950. Heavy billet counterweighted crank and steel rods.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1773
Old 02-15-2020, 07:32 AM
RAIV-Z's Avatar
Stan
Another good point regarding engine size. Not that the Raven is a ProMod
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1774
Old 02-15-2020, 10:50 AM
GTOGEORGE's Avatar
If the wheel wasn’t reinvented at least thousand times it would still be stone and it would have an e headed engine
GTO George
  #1775
Old 02-15-2020, 10:58 AM
mgarblik mgarblik is offline
Huge number of changes/up-dates in one off season. Love to see all that work being done to go faster and be more reliable. Dedication right there. I personally like the 482-500 Cu In. package better than the longer stroke, but allot of expense to make the change. What RPM's were you turning with the 4.5" arm? Any issues, or just a cautious change to push it harder in the future? When we ran the Grocery Getter with the 4.5" stroke, we felt we needed the extra cubes to get that very heavy car moving. You are probably 400 lbs. lighter than we were. Best of luck this year.
  #1776
Old 02-15-2020, 11:34 AM
Stan Weiss's Avatar
Ed,
Thanks. I knew the answer, just wanted to see what George would say. LOL
Stan
  #1777
Old 02-15-2020, 11:41 AM
GTOGEORGE's Avatar
Ed,
Stan
.........about what?
GTO George
  #1778
Old 02-15-2020, 03:29 PM
RAIV-Z's Avatar
GTO George
I don't think the concept of the wheel has actually changed much over time.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1779
Old 02-15-2020, 03:56 PM
RAIV-Z's Avatar
Thanks Mike,
Yeah, some updates were due to broken/worn parts, the main driver for changing the crank at this time was the need for pistons. To clean up a few of the bores we needed to go 0.010. The shorter stroke and aluminum rods will give us additional RPM head room as well as reliability. There were no major issues with the engine aside from the cracked damper hub and some signs of cracking on the cam key way. We're also replacing the keepers and retainers based on Victory's assessment of the valve train, they indicated we had few retainers where the taper was opening up. We did drop an intake valve last July. Victory suggested their Ti-17 retainers and associated keepers. The valves are also being lightened and we're performing a valve job.
We were keeping the rpm under 8000 with the 4.5 stroke. Did the Grocery Getter weigh over 4000lbs?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1780
Old 02-15-2020, 04:02 PM
slowbird's Avatar
slowbird slowbird is offline
GTO George
Says the guy with a roots blower and carbs. Leading edge tech for 1940
