#161
That's some good thinking...
#163
Been working on the heads and manifold for this one over the winter.
#164
462", 400 block w/displayed caps, mech flat tappet lunati, 11-1 compression, lightly ported #13 heads, e-85, vortech z-trim. 781rwhp@6300rpm on 15.5psi.....blow thru carbs sort of work. csucarbs.com |
#165
Jim - are you guys going to have it together for the Tulsa BOP race in April? That would be too cool!
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads Faster on nitrous… |
#166
JY,
Thanks. We will see very soon what if any HP improvements were made. They flow a bit better all the way through 1" of valve lift. 69, Trying hard to get there with it. Dynoing sooner than later if we have any luck. :-) |
#167
Never thought I'd hear of anyone mentioning 1" valve lift, let alone through 1" of valve lift, when speaking of d-ports...wow! Keep us posted, sounds like an interesting project.
#168
Jim, what seat angles if you don't mind sharing... valve size and back cut angles
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
#169
Valves diameters are stock 2.11/1.77. Seat angle and back cut are still in development but we are no where near the super stock guys...maybe there is more left in these. The intake roof height on these is almost .200" less than a 73 SD head...that dramaticallly affects valve seat angles
#170
Wow Jim that is a killer "D" port motor. Very nice work.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
#171
Who says "D" port heads can't flow.
#172
I think this debunks the myth that the exhaust side of d-ports is a handicap.
#173
Guess I'm gona have ta send me some of my heads
down there to Jim Robertson and have him port me a set for a few hundred dollars, Think that might cover it (buddy). ha ha just kidding. Thats one hell of a accomplisment. Nice job Jim. GT. |
#174
Wow, Go D Ports ~!
That intake is a mighty, mighty, nice looking piece also
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
#175
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#176
Ummm.... BTW NO the car did NOT back up the numbers at the track! I know a 467 bowtie with a REAL Honest 800 Horsepower (well 795.8 to be exact) the car is a few hundred pounds heavier and runs two tenths faster! Last edited by pastry_chef; 04-02-2012 at 01:33 AM. |
#177
![]() This is what I'm going by. Is this calculator wrong? http://www.wallaceracing.com/hpcalculatoreigth.php 6.1@113 at 3565lbs Your HP computed from your vehicle ET is 794.92 flywheel HP and 715.43 rear wheel HP. Your HP computed from your vehicle MPH is 839.35 flywheel HP and 755.41 rear wheel HP.
#178
Robertson car race weight was 3200 Lbs, DA was 1150'
http://forums.maxperformanceinc.com/...6&postcount=96 |
#179
#180
Jim, looks like you do nice work.
