Old 08-30-2010, 08:23 PM
eaglesan13 eaglesan13 is online now
In the latest chapter of "two steps forward and one step back" I had a problem with that aftermarket speaker when I tried to install the dash. The bracket was hitting the dash causing it to stick out too far, (first two pictures). I had to remove the speaker and open up the mounting hole so I could move the speaker back.
ID:	217035   Click image for larger version
ID:	217036   Click image for larger version
ID:	217037   Click image for larger version
  #162
Old 08-30-2010, 08:28 PM
I got the carb back from a friend of mine who rebuilt it for me so now the fuel system is done. I'm using a correct 7040563 so the evap system will be functional, (as soon as I find a gas cap).
ID:	217039   Click image for larger version
ID:	217040   Click image for larger version
ID:	217041   Click image for larger version
ID:	217042   Click image for larger version
  #163
Old 08-30-2010, 08:33 PM
Default Dash
I have most of the dash together now but I can't find the box with the headlight switch knobs and the screws for the dash bezel. I'll need some final adjustment on the ash tray and the passenger air vent. I also need to buy a new glove box lock so I can put glove box door on. But, it's looking good.
ID:	217044   Click image for larger version
ID:	217045   Click image for larger version
ID:	217046   Click image for larger version
ID:	217047   Click image for larger version
  #164
Old 08-30-2010, 09:37 PM
Sure is!
  #165
Old 08-31-2010, 12:01 AM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
I just read this whole thread and your work is outstanding!..and inspirational
Question on black underhood paint?
I saw that you used a glossy laquer on the firewall/cowl.
But what did you use for the fenderwells? and core support?
One of the Eastwood rattle cans that line your walls? Or did you have them sprayed?
chuck...
1973 455 TA (07A)
  #166
Old 08-31-2010, 07:57 AM
I used the same paint on the cowl, firewall, fender wells and core support. The paint might look glossy in the pictures but it's really not. I used PPG 9266 black lacquer which is what the factory used. I don't know if it is 30 degree, 60 degree, or what, but it looks just right to me. The Eastwoods underhood black is very close but it does not have the same "sheen", it looks a little too flat to me.
  #167
Old 08-31-2010, 11:12 PM
LeighP's Avatar
LeighP LeighP is offline
Looking very nice!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #168
Old 09-11-2010, 02:09 PM
Well I went to put my tach harness in and I had forgotten to drill the hole in the firewall (my car originally came with idiot lights). So, I got to practice taking off my drivers side fender so I could drill the hole. Fortunately there was a very informative thread on the subject which had pictures and an explanation of just where to drill. I should take this opportunity to thank all of you who freely share your knowledge and past experiences with others. It is the best resource for dealing with problems. I used a 1 1/8th hole saw to cut the hole. The grommet is used on two other places on the car, the blower motor wire where it comes out of the firewall (non a/c) and the passenger side core support where the forward lamp harness comes back into the engine bay for the right front corner light, so it's a pretty easy part to find.
ID:	218235   Click image for larger version
ID:	218236   Click image for larger version
ID:	218237   Click image for larger version
  #169
Old 09-11-2010, 02:14 PM
Default Steering column
My car originally came with the plastic steering wheel and I wanted to convert it to a formula wheel so I had to paint the steering column black. I used the same PPG black lacquer I used on the firewall, core support, etc... Interesting that it appears the column was originally painted sandlewood while it was assembled.
ID:	218239   Click image for larger version
ID:	218240   Click image for larger version
ID:	218241   Click image for larger version
ID:	218242   Click image for larger version
  #170
Old 09-11-2010, 02:17 PM
I restored the formula wheel collar myself rather than buy one. The first time I painted the collar the texture sagged and I had to strip it off again. The second time around I read and followed the instructions on the paint can and it turned out just fine. Go figure!
ID:	218244   Click image for larger version
ID:	218245   Click image for larger version
ID:	218246   Click image for larger version
  #171
Old 09-11-2010, 02:22 PM
Here are some pictures with column in. I have one each of the gear shift sticks so I could go console or non-console. I really like the look of the non-console with the low back seats. However, with sandlewood interior being two different colors that color interior looks good with a console. Decisions, decisions!!!
ID:	218248   Click image for larger version
ID:	218249   Click image for larger version
ID:	218250   Click image for larger version
ID:	218251   Click image for larger version
  #172
Old 09-11-2010, 03:21 PM
Default Steering wheel
I bought this steering wheel from a board member (455HOTA) about a year and a half ago. It's been sitting patiently in a box waiting to be used. It's not original, it's been leather wrapped, but it looks real nice and has a good feel to it. The center cap and emblem is a swap meet purchase that cost me $9.00. It was dark brown but I used SEM landau black on it and it looks new.
ID:	218258   Click image for larger version
ID:	218259   Click image for larger version
ID:	218260   Click image for larger version
ID:	218261   Click image for larger version
  #173
Old 09-11-2010, 03:41 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
it's all looking great! Did you have to do anything to your woodgrain dash bezel or was it in that nice of shape to begin with? It has a nice sheen to it almost like it has a satin clear on it.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #174
Old 09-11-2010, 03:44 PM
njsteve's Avatar
njsteve njsteve is offline
What are you doing with the old tan steering wheel? Like an idiot I threw the tan one from my grandmothers car out years ago when I swapped to a different wheel. Been looking for another one for a while, now.
  #175
Old 09-11-2010, 04:32 PM
CaptCrunch CaptCrunch is offline
looking great!..........going to be a nice one when it's done..........
  #176
Old 09-11-2010, 09:06 PM
I used Pledge. I had an old wood grain bezel that was in bad shape so I tried the Pledge on it first just to be sure it would not ruin the bezel. Here are some pictures of the test peice. I used the pledge on the area between the bird emblem and the small gauge pod opening to the left of the emblem. I just prayed it on a clean rag and wiped in on, it cleaned off all the dirt and gave the wood grain a nice finish.
ID:	218278   Click image for larger version
ID:	218279   Click image for larger version
ID:	218280   Click image for larger version
ID:	218281   Click image for larger version
  #177
Old 09-11-2010, 09:08 PM
Steve,
I had planned on keeping it, but let me think it over. If I decide to part with it I will let you know.
Chris
  #178
Old 09-11-2010, 09:57 PM
RicksGTO's Avatar
thanks for the tip, I'll try some pledge on mine.
  #179
Old 03-27-2011, 03:55 PM
It's hard to believe it's been six months since I last posted, but I kind of took the winter off. Here are some pictures of a few the small stuff I did when weather permitted.
ID:	239251   Click image for larger version
ID:	239252   Click image for larger version
ID:	239253   Click image for larger version
  #180
Old 03-27-2011, 03:57 PM
I probably should have painted the under side of the hood before painting the car, but...
ID:	239255   Click image for larger version
ID:	239256   Click image for larger version
