Old 03-22-2014, 08:41 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Don, PSI.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 03-24-2014, 08:22 AM
dci dci is offline
I have a question for the ones here that say a shorter deck is needed. If our lifter bores are all in line, and we run offset rocker arms of up to .850" with only a .180" offset in the lifter. Won't the shorter decks create more stress and side load on the pushrods? I'm not saying that i do not agree with a shorter deck, but it's a little more involved than just shortening the deck. The other part of this equation is the actual need for shorter decks. Until we can spread the bore spacing out to get bigger bores. I think we have the ideal deck height right now. The only way for us to get more cubes is to go with longer strokes and we need deck height to do that.
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 03-24-2014, 08:55 AM
J.C.you's Avatar
Don Johnston
330-850-5050 shop
330-628-3354 cell
good point if you leave the cam tunnel alone. But a short deck with some judicious mods to the tunnel, bores, and cam would make things better.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 03-24-2014, 11:33 AM
Don Johnston
330-850-5050 shop
330-628-3354 cell
Yes and no...for big cubes a longer wider deck opens things up quite a bit and allows us to have same (or greater) bore advantage. Beside head flow, bore size(spacing) is pretty much a large factor in why Pontiacs arent making NHRA pro-stock power at 500 ci now. Bore size dictates valve size ultimately dictating HP! In the VE picture stroke wont get you there.
However the short deck at current bore space(even with std lifter bore placement) offers us some different opportunities... 400-454 ci LS and SBC, SBF, SBM, combos are rather popular with combos from mild to wild... and some stout 327- 370 inch packages are out there as well...
I strongly feel we should focus on the 400-460 inch segment until we have the stretched blocks(heads too) to go toe to toe with the bad boys 500 ci up. We are doing good there to a point, but the bore advantage they have does show up in the upper levels though. So... its about time we go LS hunting instead!
We have bore space advantage in the 400-460 inch range if we use our 301 deck height(or close), the 10.2 deck doesnt allow the lighter recip etc... that a shorter deck allows.
Shorter deck also eases packaging in tight places like 82-up small light cars... the 301 deck height still allows over 460 ci combos but then it competing against bigger bore motors. The 301 deck would allow us to do ok in the 300-400 ci range but an even shorter deck might do better...
As far as offset lifter cups and rockers... its not the best way to go about it. Crower prefers no offset and up to .150 on the lifter cup can work ok but beyond that the side loading on roller axles becomes a new issue to deal with. Big angle offsets in the pushrod affects side loading of rocker pivots.
If you are trying for high rpm, using offset lifter cups and rockers, makes the task harder. Dealing with one arc of travel is far easier to control than a compounded arc. (Think valvetrain control and spring life/roller axle and rocker maintenance).
A change in the lifter bank would be better... revise all our block castings to allow simplified changes that can easier accomodate standard lifter placement with the option to deliver block with no lifter bores drilled for placement wherever, however, whatever, any particular head design needs them to be.
The lifter bank just needs to be a continuous rectangle the length of the valley... revising the cam tunnel while your at it to allow bigger journals and options in height would be a good thing as well. Such a revision allows for an easier way to control the valvetrain allowing more time and resources channled to making power. One other block revision could have options on main bearing bore size but 3" will work ok for many apps.
RPM is a very important element in making power... High rpm was never a Pontiac's strongest attribute, as Pontiac had neither the heads or the block to support it... We have plenty of killer head choices for the "smaller" ci combos we could build with a short deck. The block revisions I'm suggesting opens the door to new head designs.
IMO the short deck sells better than a longer stretched block does, as it allows quite a few existing components... Other than intake manifold, any other obstacles like existing headers or lack of stock replacement valley covers are very minor.
Until there is consencus on a stretched block and how much it gets stretched... 301TTF makes more sense.
Old 03-26-2014, 03:45 PM
dci dci is offline
I would agree with that if we are class racing and had a cubic inch limit, but for the average Pontiac bracket racer. I think we have a very good platform to build on. Heck even the LS guy's are pushing for taller deck heights. I think they have a taller than stock deck now at 9.700 and heard roomer of a 10.100" deck block coming out soon. I don't want you to think that I'm arguing or disagreeing. I am just trying to understand the logic for what the majority of our group would need or use it for. I think if someone is trying to build a smaller cu in engine to achieve close to 3 HP per. Then maybe a new designed from scratch short deck block would be in order. I think personally that a block with improved lifter bore area, and a raised big bore cam tunnel would be more useful. Maybe I am the minority though !!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 03-27-2014, 10:57 AM
Tiger Paw Tiger Paw is offline
Bruce, your right about what is needed to go hp/ci racing. The problem is there aren't enough people willing to start with all new pieces and cost of doing that. All new castings and pretty much everything else would need to change (relatively).
The biggest issue the Medium block Pontiac has is available space for valvetrain, valve size and cam/lifter/pushrod geometry. Removing the lifter bores entirely and designing an assembly similar to the Ilmor Indy car pushrod engine. Getting a killer valvetrain would close the gap considerably. No new castings, not have to buy a bunch of anncillaries just a fresh approach and a fair amount of design and a few new small parts.
My racing years are over, but maybe someone else with dreams and plenty of time.
Old 03-27-2014, 11:05 AM
When I say there aren't enough people interested in hp/ci racing, I am referring in general, even Comp Eliminator which is exactly that can't come up with a full field and IHRA Modified folded years ago. Much of that has to do with cost of racing. When it is all about Horsepower (purchased) and less about individual skill, the deepest pockets win. THAT SUCKS, a guys wins cause he's rich. Comp style racing won't last long.
Old 03-27-2014, 11:33 AM
Chad Speier Chad Speier is offline
Comp Eliminator is more than deep pockets. It's about ingenuity, about pushing the limits, and lastly about technology.
If Comp dies, the trickle down effect will cause the average bracket racer to die as well.
Old 03-27-2014, 12:10 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I agree. I think a lot of racers have moved to outlaw racing, especially the 1/8 mile stuff. There is a significant shift in our sport. I think it is for the better but we will see.
Old 03-27-2014, 01:15 PM
Chad, how many Comp guys buy engines? How many build their own? Ingenuity absolutely required. Not likely that Nickens, Jenkins RIP, Sonny L and WJ (I'm told did engines for this years Champ) will break new ground in search of Pontiac power.
DCI, McCarty, Butler or somebody with engineering working with will have to do it.
When I quit Comp Sonny L Chevy hemis ran me out of A/AA $75K per engine. Now WJ?
Old 03-27-2014, 01:30 PM
I'd say 50/50 buy vs build. But to be clear, no one would ever build a Pontiac to run Comp. Makes no sense when you can buy anything GM that is already R&D to death and run in a Pontiac.
You will have a hard time buying a SBC top builder engine for $75K. However, a little guy can win races and set records as well. In fact The Champ has Neil and Parks build his chassis and they run A/ND. I do their heads. The Champs rear end bill was over $100K last year..
Old 03-27-2014, 03:19 PM
Comp guys who build their own are my heroes! A lot of people have no clue as to how much effort and money goes into racing in Comp.
Some of the ingenuity can help here. Fuel some thoughts to include a higher level of Pontiac. And if somebody wants to run with it great. I think a 400ish ci Pont could go pretty fast.
Old 03-27-2014, 05:51 PM
KO KO is offline
the biggest problem with Comp is a guy can obliterate the index and just move to a different class w different car engine or both
1989 Automotive Hall of Fame Inductee
Old 03-27-2014, 06:08 PM
A bigger issue is most fans don't understand the class.
Comp is a way of life!
In 2006 my father and I spent $125K on a new G/EA '32 Bantam, trickest car on Earth. Weighed 1200lbs with me in it. Built a SB2.2 4 cylinder and had spare parts from hell. It was the year Aragona won the Championship and Coan was chasing it as well. Both guys were running G/EA. The index was lowered .24 in 3 months. Try selling off that stuff! LOL..
Old 03-27-2014, 11:33 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Comp was the stepping stone to Pro-Stock.
The fastest of the fast with so many different combinations.
It proves why a conventional Pontiac will never compete in a HP/CI class against other brands.
Calvin Hill
Hill Performance
708-250-7420
Old 03-28-2014, 05:23 PM
KO KO is offline
Calvin Hill
Hill Performance
708-250-7420
I think I have a Pontiac combination that can compete. NHRA SS/CS 10#/CID WITH AT 10.30 index, 9.2x record cast iron inline valve only The Chevy combinations are using the 23 degree Bowtie Vortec head @ around 300 CFM. I think a iron Pontiac head can outperform that
Old 03-30-2014, 12:16 AM
That Vortec head is a pretty good piece. I just finished a set of un-ported with creative valve work that went over 260 CFM. The valve size was 1.960".
Get that entry area opened up and flowing 300+ and make some noise, I would love to see a traditional Pontiac compete.
Calvin Hill
Hill Performance
708-250-7420
Old 03-27-2014, 06:13 PM
KO KO is offline
take that motor put it in a dragster, kill that index, or add dry sump and another carb and a 5 speed, just takes money,
Old 03-27-2014, 06:14 PM
Index should be taken for a win or a Championship.
Old 03-28-2014, 08:54 AM
dci dci is offline
The only thing I see keeping a Pontiac out of comp is someone willing to spend the money to do what it takes. If you walk through the pits and staging and look at some of wild set ups these guy's have. You will be blown away by their creativity. Some of the cylinder heads I seen on these cars look like someones science experiment gone bad. They have globs of weld,putty,and screws holding everything together LOL. I asked one guy how he keeps water in the engine and his response was. We don't run coolant anymore. We push it to the burn out box make a pass shut it off and tow it back. Comp people are in their own little world and the only thing that limits them is their imagination. Of course it helps having the funds to make it all happen. Now on the other side of the coin. Pontiac people are in their own little world. We try and keep everything stock appearing and low maintenance and rarely step outside our comfort zone. I am not saying that is bad. I am just saying I believe we limit ourselves by trying to be unique in our way. I have to say that it is cool to see a Pontiac with 6X heads run with a Chevy that has been modded out. I just want to see Pontiac's step up their game a little, and we are a little bit at a time. Our cylinder head selections now are very good and versatile. So the only thing we need now are Pontiac people willing to do what it takes to compete with brand X. There are a few that have stepped up to the plate, but we need allot more.
Don Johnston
330-850-5050 shop
330-628-3354 cell
