In 2013, I had my current 469 built by Calvin Hill. We used a 455 block, #48 heads that he ported to 235 cfm and a Lunati SFT cam selected by Calvin. The block is zero decked and the pistons are 29cc dished, giving me a cranking compression between 165 and 170 PSI. I sent my Q-jet and Pertronix distributor to Cliff for him to work his magic and recently added a ported cast iron intake. On 90 degree days, this engine does not ever climb over 195 degrees regardless of how hard I drive it, and on days under 50 degrees it never gets over 175.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
I've been watching along on all your cooling threads. It looks like you have confirmed that the restrictive shroud was causing a problem on the highway, but I bet that you will need a shroud in traffic during summer heat. At least you have six months or so to consider how to tackle it if that becomes a problem.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
