I really don't think there is that much difference between hydraulic flat tappet and HR grinds, or not as much as folks think.
We can easily mimic the power of a HR grind with a very well chosen hydraulic flat tappet cam topped with Rhoad's lifters and high ratio rocker arms. We did that test a few years back right on the dyno between the Crower 60919 cam and a custom ground Comp HR cam with 230/242/112 specs. It had .361" lobes and quite a bit more lift than the 60919 cam, but only made 3hp/4ft lbs more torque on the dyno in back to back pulls. The Crower cam had 1.73 rockers on it, and Rhoads lifters, and actually made peak power 200 rpm higher in the rpms range than the custom HR cam. On back to back pulls we saw 494hp/540tq from the 60919 cam, and 497hp/544tq from the HR. Then we put the high ratio rockers on the roller cam and started swapping intakes/carbs/spacers, and ended up making 514hp/567tq by the time we were done, so it did open things up for more power with some additional work The test still shows how well a flat tappet cam works in these engines, and we can "tame" it some with Rhoads lifters and bring on big power with high ratio rockers. We recorded 12" vacuum at 750rpms with the 60919 cam, and 13.5" with the custom HR, so you really can get it done with a roller cam with less seat timing. The Crower cam had 304/314/113 specs, and 231/240 @ .050". The HR was 284/296 seat to seat, 230/242 @ .050". The test engine was my old 455 with unported KRE "D" port heads with 85cc chambers, so about 10.5 to 1 compression........Cliff
Another board member went mid-11's with the XE274 in a 400 engine, still a very poor cam choice for a pump gas 455 build at any compression ratio, IMHO. Some guys just have cars that are very well set-up to effectively use the power they are making, so can run good numbers with those parts, or just about any combination of parts that make decent power.
I also have a customer that runs well into the 11's with a 455 using the XE-274 camshaft and iron heads. His heads are very well ported, and bowls "hogged" extensively and 45 degree seats. Compression is pretty high as well, and he uses stamped steel rocker arms and light valvetrain components. This really helps as it doesn't take nearly as much valve spring pressure to keep things in check and avoid "lifter crash" at high rpm's. So his 455 revs well past 5200rpms and makes good power with the heavily ported heads. We see most of the XE cammed engines go "dead" early in the rpm range, even the ones I've had on the dyno are DONE by 5000rpms or so. I attribute this to the ultra quick seating velocities, and harmonics that develope at high rpms as a result. Instead of trying "tricks" to get those cams to work, we just pick better cams right to start with, that don't require extra spring pressures, super light valvetrain components, 45 degree seats and heavy bowl work, etc. These excellent results with XE cams NEVER happen with the smaller ones, and even with the larger grinds fall into the same catagory as the guy that runs into the 10's with a completely stock fuel system and stock mechanical pump. For every guy doing that deal, there are 30 guys that can't get out of the 13's trying to do the same thing........FWIW......Cliff PS: NICE numbers on the W-72 stroker build!
"Let me simplify it, with this question. Will using 1.65 rockers put more strain on the pushrods, lifters and cam lobes, than using 1.5 rockers ?"
Figure EVERY BBC has had 1.7s(348-409s 1.75) BBF 1.7 + , every LS motor in trucks and cars 1.7+. Yes it will put some mechanical stress more than a 1.5 but figure all these factory motors had even higher than 1.65s it must not be that bad.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I've been lurking and have enjoyed this thread. |
When lift is limited,and all you can do is add duration,the nose up-over peak lift will have to flatten out to one degree or another (no pun intended). And I know you learned a bunch more about that deal after spending some time over @ the stocker forums @ classracer.com. Quote:
Only reason the SD455 used a version of the 744 cam was they could'nt get the 041 version smog legal for the SD455,and remember '73 was a big rollout year for smog equipment,so they were sorta caught behind the 8 ball on that deal and they had to do what they had to do. The 744 cam is nothing like the modern cams that are roughly the same,the modern cams will have nowhere near the same amount of seat duration,and the additional lobe lift allows for a much better nose profile. There is a long thread here about the 744 cam,with pics comparing the 2 lobes you mention IIRC,and it's a night & day difference. As for the rocker ratio deal,as was mentioned if using the same springs,of course there will be more stress on the valvetrain with a higher ratio rocker,that's simply because any time the lobe is off the base circle there's going to be a higher lift seen @ the valve and the springs rate determines where the open pressures will end up with any given lift @ the valve. It's not that more force is required to lift the valve,as you mentioned Don that's more or less a constant with a given spring set-up,it's just that you are going to be lifting the valve open sooner (and afterwards opening it further) with the higher ratio rocker,as it is effectively adding duration/lift to a given lobe just as soon as it cracks the valve off the seat. But as Steve C. alludes to,there's waaayyy more to spring pressure dynamics that dictate whether more/less spring pressure is "better",even for street use. Seat pressure is all about preventing the springs from bouncing off the seats when the valves are closed,go too light on the seat pressures and you'll kill a cam quicker that way than you would've by using too much seat pressure. And open valve spring pressure is all about preventing floating the valves or "lofting" the lifters off the cam at/around peak lift,again making for a very short lived cam & valvetrain. It's a fine line between "not enough" ~ "just enough" & "too much"... So yeah,less is'nt always better when it comes to valve spring pressures. And yes,using a lower ratio rocker during cam break in is another measure often used to help that process. Some cam co's even offer low ratio rockers (1.2/1.3 ratio) for exactly that purpose. HTH Bret P. |
That's simply because there's no valid reason to even push the CR to 9.0-9.5 for a mild "street" combo like that. Stock converter and low numeric gears like that are gonna complicate the cam selection options somewhat. Now lets say it's a 9.5:1 455 w/a 2500 converter and 3.42 gears and yeah your cam options tend to open up somewhat. This is where cam selection becomes entirely subjective,hence why you'll never get the concensus you seek,as the devil is in the details as they say. What cam I might choose myself is not always what I would recommend to someone else. Without knowing who's car it is,and what they're goals are for the combo,this would largely be an excersize in hypothesizing,and that sorta thing is mostly a waste of time IMO. The "one size fits all" paradigm for cam selection does't work well if you ask me. It's strictly a case to case basis. FWIW Bret P. |
And the survey said: 185 posts.
![]() This is a very popular thread. And to me, it's real similar to some of the "which alum heads are better" threads. It seems to depend on who you ask. If you say the steep ramp cams are not too good for a 455, somebody will come on telling how great their engine runs with an XE cam. And if you say Rhoads lifters work good, somebody comes on telling of their bad experience with 'em. One will say rollers are better in most all situations. Another will say that certain flat tappet hyd are almost as good as a very popular roller. And on and on it goes. So I wonder if some of you guys who really know what's going on, can agree on at least some basic guidelines for 455 cam specs. Since this is the street section, lets assume 9-9.5CR, with unported iron heads, 3600lb car, 3-speed auto, stock converter, 3.08-3.23 gears. Advertised duration: The steep ramps advertise 256 & 262 for their smaller cams. The 041 is sometimes said to have 308/320. So, for the combo mentioned, what advertised would be considered too low and might cause detonation? And how much would be considered too high, for 9.5 CR ? Dur @ .050 lift: The smaller cams are in the 2teens. The 041 is around 231/240. So, what would be the best range for this app, to give a good idle, plenty of vac, and decent power to 5000rpm ? LSA: I've read everything from about 106 to 115. Again, for good idle and vac, narrow the desirable range down some. 110-112 ? 112-114 ? or ? Lift: .407-.525 What's a good range, for good performance, without high spring pressures ? .425-.475 ? .450-.500 ? or ? Now--with your answers to those questions, list some shelf cams which you would recommend, which fall into this category. This is to help those who are trying to decide on a cam for their engine, to narrow their possible choices. I'll go 1st, whether I'm right or wrong. I personally consider the 068, with 1.5 rockers just too small for a 455. So, the smallest combo I'd consider is an 068, with 1.65 rockers. But, since the Summit 2801 is basically a high lift version of the 068, I'll make it my #1 choice for the smallest cam I'd use. My choice for the next larger size is the Summit 2802. Then I'll go with the Crower 60243. And, of course, the cam I'd actually use in my 455 would be the 041 grind, with Rhoads lifters. I can see no reason to go with a cam any larger, for this app. Again, I'm not talkin about max hp, or lowest ET, but a good, highly streetable pump gas HFT cam for the app mentioned. So, let's see what you guys recommend. No special custom grinds, just name brand cams that a guy can order online, from somebody's shelf.
What cam to use ? A computer cam selection ?
Many years ago Denny Wyckoff at Motor Machine & Supply in Tucson along with David Vizard developed a program called 'Cam Master', a comprehensive computer program that offered precise cam selection. It was a empirical program based on over 50,000 individual engine dyno pulls on various engine combinations. Written up in National Dragster and other magazines. Cam Master was not duration-driven but overlap-driven. The event timing of the cam, dictated by the duration of the intake and exhaust, together with the lobe separation and the advance/retard position in the engine. Once the overlap to suit a given application is decided, everything else falls into place. And it thrived on maximum valve lift ! For interest using the program on one senerio for a 4.210 stroke/462 Pump Gas combo. In part, it was based on 76 degrees overlap. The program used 70 to 90 degrees overlap for a street/strip application. Input: solid roller cam, 1.65 rocker ratio, peak power rpm 5800, using a 2.150 diameter intake valve with 313 cfm cylinder head flow at .600" lift, 6.625 rod length, intended 9.95 static compression ratio. The results came back with a cam suggestion using a vary narrow 106 lobe LS and a suggested 286 degrees intake duration at .20" tappet lift. Interesting because at the time it just so happen UltraDyne had a solid roller rated with 286 degrees @.020" tappet lift, 253 at .050", and 0.4033" lobe lift .... 0.665" gross lift. In the actual engine, that had a piss poor 9.7 compression with alum heads, I used a XE solid roller with 254 degrees intake duration at .050", ground on a 108 lobe separation and .... 0.620" valve lift (it was a street engine). To good to be true, peak power on the dyno was at 5800 with a Performer RPM intake and 6000 rpm with a single-plane intake. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 06-19-2015 at 01:16 AM. |
For interest, similar from about 13 years ago by Ken Crocie. A 455 based combo, about 285-288 cfm 'cleaned up' alum heads, 10.2 compression, Performer RPM intake, a 'big' Comp 320H hydraulic flat tappet cam with 268 degrees at .050", 110 LS and 0.606" net lift at the valves.
Produced the exact same peak power at 5800 rpm on the dyno. Like Cliff eluded to here, if you examine the actual lift curve at the valves, this modern quick-lift hydraulic flat tappet cam, in conjunction with high-ratio rockers and Rhodes Vari-Duration lifters approximated the valve-lift curve of a traditional solid roller to about .600" valve lift. But it's going to take additional intake duration. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Denny Wykoff, haven't heard that name around these parts in years. I knew Denny years ago, I think while he was working on that program, or shortly after he did it. He was telling me about it one day. Never used it though. Not sure what Denny is even doing now. He sold Motor Machine off years ago.
Excellent thread. I have a 9.0 to 1 455 with a comp 275 deh and its always on the edge of detonation with 91 octane. The Crower 60243 and howards 410051-14 285-295,231-241,114 both look like better choices to me than the 275. does anyone have any experience with these cams? Thanks for any input.
69 Firebird, 462 turbo 400 3000 stall, 8.5 323 rear
"It's a fine line between "not enough" ~ "just enough" & "too much"...
So yeah,less is'nt always better when it comes to valve spring pressures. And yes,using a lower ratio rocker during cam break in is another measure often used to help that process. Some cam co's even offer low ratio rockers (1.2/1.3 ratio) for exactly that purpose." I have some SBF 1.33 ratio break in rockers I got form Paul Spotts years ago I used on my current pump gas motor. I would bet most of the time we really don't know what EXACT spring pressure is the best unless we had a Spintron! And whether you actually loose performance if you are loosing pressures you would only know by track times in a consistent vehicle. And gosh start talking duration splits 4,6,8,12 degrees, single pattern or reverse split and you open a whole new can of worms compared to what a Pontiac "has to have".
You only have to put a roller cam and flat cam side by side to see why a roller can "get it done" with less seat timing. The ramps are extremely "steep", and the valves reach full lift quickly, and stay there for quite a few degrees of engine rotation. To "mimic" this deal with a flat cam, you are going to have to have more duration (seat to seat), which will degrade idle quality with any given cam profile. We add the Rhoads lifters to take away some effective seat timing at low rpms, or variable duration. Then we add high ratio rockers to get the actual valve events more on par with roller profiles. This is often referred to in this business as "area under the curve". The high ratio rockers let us do more with less, in terms of movement of the tappets per cycle. They may add a bit more stress to the parts as some have eluded to, which is never a good thing with flat cams/lifters.
So in basic terms, a very well chosen HR cam topped with Rhoads lifters and high ratio rocker arms is basically a "poor mans roller cam" set-up, and it does make great power at a fraction of the cost of a complete roller cam set-up. In recent years, we switched to roller set-ups not so much for the power, but to take "scrubbing" a lobe out of the equation. I still like flat cam set-ups, and we are now experimenting with coating flat cams for improved durability. I really think that it will work well, as this technology has been out there now for quite a few years. We're about to put our first one in service, in a 412cid Pontiac engine. We polished the cam in our shop lathe and sent it out to be coated. It just got back and we're finishing the assembly in the next week or so. I really think that coating the cams will be the hot ticket and we may start going back to flat cams for a lot more of our engine builds, as I love the ability to use the Rhoads lifters and high ratio rocker set-ups, and at this time I'm not overly fond of any of the hydraulic roller lifters being produced (retro-fit). I've had numerous issues with them, including the engines going "dead" at high rpm's. The "hybrid" set-ups (HR cam/HIPPO solid roller lifters) in contrast will rev right past 6000rpms so fast you can't move the shift quick enough! It may be some time before we know how well the coated stuff is going to work, but I'll make sure to post the results as they happen.....Cliff
Would be good if those coatings end up working but wondering how long it will take before any long-term results are known. I really couldn't care less about the noise Rhoads lifters make, it's the sound the engine makes at 5000 RPM that I'm after!
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
How will you know if its the coating that saves the cam or just being one of the lucky ones that doesn't have a problem? |
Steve I think I had them run the same cam program for me for my first E head motor and it was a pretty unusual recommendation with LOTS of lift.
Your right Skip, Cam Master did recommend lots of valve lift, and often not an achievable amount. And within his tech material presented David Vizard himself is a proponent of lots of valve lift.
With the scenario I just mentioned the results suggested 0.4980" lobe lift, or 0.747" gross lift with a solid roller cam as input. With the computer results topping the list was valve lift. Bottom line, the engine wants all the lift it can and thrives on it so run as much as mechanically achievable or prohibitive to you because of cost and/or budget limitations (such as in a purchase for solid roller cam, longer valves to increase installed height, stronger springs, etc.). Obviously if it's a street application or race application will have a bearing on the situation, most here would be hesitant to run 0.700 lift on the street. This info published by David Vizard, it might be of interest: VALVE LIFT. "A 2-valve cylinder head typically continues to flow more air up to lift values equal to as much as 0.35-0.4 times the valve diameter. The reason for this is that there is a flow pattern transition period that takes place at a lift value of about 0.25 of the valve's diameter. When this point is passed, if the port has been modified to support flow in this lift region, the valve efficiency actually starts to increase. This is the reason why a 2-valve engine responds to high lift." "If you want to build a street motor with the most power without a sacrifice of idle and low speed qualities, then lift is the most important factor to maximize, not duration. The best street cams are those that seek to maximize lift while only adding a minimal amount of duration." .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 06-19-2015 at 11:36 AM. |
Thanks for response B-man, I figured if it drove well with the manual brakes, I'd leave a little "room" for cam selection, and figured that with standard lifters I could get by, although it took a bit to get the idle smoothish with the tripower and 274, and I'd probably appreciate the smoother idle the rhoades would provide, I'd be interested to hear them in person before committing to using them.
But we did not clearance the heads for 1.65's while they were off last year (should have been done, I did ask him to), so I would likely be staying with the 1.5's, although it seems that cam (041) can do reasonably well with the 1.5's If this engine continues to run reasonably well, it may just stay the way it is .....good to have a "plan B" though |
The "hybrid" set-up takes the hydraulic action of the lifters out of the equation, so they will rev right past where HR lifters give up without additional spring pressure. Really tight lash is required when doing this, so it's not for everyone. If they made better HR lifters, designed from the ground up as "limited travel" and for high rpm use, I'd go that direction instead.
I have noticed they are making changes to the HR lifters, even though they (the folks making or selling them) aren't saying much about it. The spring in the bodies is stiffer in recent units, and they have shortened the travel up a bit, but I'm not sure if they will rev harder or work any better at high rpms with "standard" weight parts than the earlier designs? As for the cam polishing, we used super fine auto body sandpaper, starting out with 600 grit and clear up to 1500 finish, or basically a "mirror" finish. They have been coating NASCAR cams for many years, and claim zero issues anyplace. We'll certainly find out, as we hope to have our engine in use and start flogging on it in the next few weeks.......Cliff
