Old 04-22-2016, 02:25 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Originally Posted by mike leech View Post
... Digital 7
Matching coil
Moroso wires extra sheilding
Msd distributor with pro cap...
Crank trigger? Hall effect?
Old 04-22-2016, 07:51 AM
mike leech's Avatar
mike leech mike leech is offline
Crank trigger jack
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 04-21-2016, 08:28 PM
455firebird1969's Avatar
No sleep for the wicked...congrats Mike. Rain is not suspended in air. Air temp is directly related to its ability to retain water vapor. What was the temp, that tells more about your conditions, unless you want to divulge the entire armospheric environment.
Old 04-21-2016, 08:44 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Congrats Mike! You take persistence to a whole new level! Lol. Now get that bad boy in the car and make some hits.
Brian
Boobs & bacon
Old 04-21-2016, 08:52 PM
mike leech's Avatar
LOL!!!! Really. So water falling out of the sky is not suspended? I know all about moisture in the air. More than you might think. Dynoing on a rainy day will make less power due to a much greater amount of water in the air. That's why you need to add more timing too. but feel free to think watever you want.
EHTTFMF!
Old 04-21-2016, 09:21 PM
Probird's Avatar
Probird Probird is offline
Very nice Mike!!
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 04-21-2016, 09:25 PM
I'm basing my statement from meteorological facts. What was the air temp? That will dictate the maximum water vapor content. And no, rain is not water vapor, so it does not affect density altitude. Rain is liquid, it is not suspended in the air.
Old 04-21-2016, 10:01 PM
john marcella john marcella is offline
Water grains affect me at the track huge! I look at that as much or more than anything else.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 04-21-2016, 10:06 PM
mike leech's Avatar
Ever seen an engine lose 20 hp on back-to-back days up to the same Dyno?
EHTTFMF!
Old 04-21-2016, 11:10 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Great power mike. Very impressive.
Old 04-21-2016, 10:05 PM
mike leech's Avatar
LOL again. You're killing me here. Obviously falling rain is not suspended or it would not be falling. I don't really care about meteorological facts or summations. I'm pretty sure it would be atmospheric facts but i digress. I have my very own psychrometric chart and know how to use it quite well. I also have zero interest in debating what it might have made or should have made or might make somewhere else.
I handle moisture issues and solve problems relating to moisture for a living. I also regularly explain these conditions to engineers and environmental people. So please just let it go. If you THINK the dyno corrects for these conditions AND that the correction is a true and accurate representation then good for you i guess.
I know better. I've seen the same engine hooked to the dyno make 25 hp less on consecutive days due to weather. And it was not raining. Just humid.
And besides i posted the sheet.
EHTTFMF!
Old 04-21-2016, 11:12 PM
mike leech's Avatar
Thank you all for the kind words. Time to go in the car!
EHTTFMF!
Old 04-21-2016, 11:51 PM
cfmcnc cfmcnc is offline
Great job Mike and All involved.Its fact dyno on a bad day makes less ,corrects less and you have to change tune to deal with water in the air.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
Old 04-22-2016, 01:38 AM
slowbird's Avatar
slowbird slowbird is offline
Nicely done Mike!
Old 04-22-2016, 05:44 AM
Maybe the low pressure air that is normally associated with rainy atmospheric conditions is where it went? Your engine is a bad Poncho and that's all I really care about. Congrats on keeping it together and thanks for sharing this info.
Old 04-22-2016, 10:29 AM
Elarson's Avatar
Elarson Elarson is offline
Humidity displaces oxygen. Think of it this way. Every water molecule in the air going into your engine takes the place of a useful oxygen molecule that would have otherwise gone in.
Rain isn't the culprit directly, but a rainy day has high humidity.
Eric
Old 04-22-2016, 11:01 PM
Eric
My initial point was rain is not water vapor. (Mike said he did it in the rain). Water vapor affects density altitude (which affects performance), rain does not. Rain is the result of atmospheric conditions. If he had stated he did it in low pressure air or poor conditions, I would not have provided input. My point is cold air cannot hold as much water vapor when compared to warm or hot air. Simply because it is raining, does not necessarily mean you have a high water vapor content. High humidity does not indicate high water vapor content. If the air is cold, things change. Saying a rainy day has high humidity is vague unless you include the tempurature.
The psychometric chart indicates 50 f. air / at 90% humidity holds 49 grains per pound water vapor.
While, 90 f. air / at 70% humidity holds 150 grains per pound of water vapor.
37 f. air with 100% humidity can only hold 33 grains per pound.
Mikes performance is stellar, and I congratulated him, it's not about his achievements.
All I'm trying to do is help those reading this to understand how meteorology works.
Old 04-22-2016, 11:12 PM
mike leech's Avatar
Really? Thats what you're trying to do? I'd rethink that.....
Several credible sources have pointed out the truth about dynoing on a bad air day and its effects. One that owns and runs a dyno. Maybe the learning opportunity is closer to home than you think. No offense. But who the hell thinks the the water grains are not high when its a rainy day. Come on.
A lot dyno cells use shop air for the input. So that adds to the issue as the temp comes from the shop and the water grains and pressure ar fed by the atmosphere.
EHTTFMF!
Old 04-22-2016, 08:24 AM
Money Pit's Avatar
Money Pit Money Pit is offline
That is one bad bitch! Congrats
Old 04-22-2016, 08:50 AM
cosgrove cosgrove is offline
Good result Mike. I'm sure the power will show in the car.
Torque had a nice sweet spot at 7700, just like you predicted.
Power was down some by your predicted peak of 8600. I can hear the turning gears in your head from Iowa.
Might have been the air, but I bet you get just a little more air in and out of that thing before it ever goes on the pump again.
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142
