I will go back first of the week to see what else Mike finds.Tom
What about my favorite, #4 ?
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The bearings were Clevite Performance, either P or H. My invoice doesn't say which, I can't remember. Both the machinist and Tom are very confident in the diagnosis.
I see damage to the block in one of Tom's photos (attached and circled in red). Curious what you all think of the block damage and the blocks future prospects. The spark plug thing is a mystery. There wasn't a drop of oil leaking. 6.5+ quarts in the engine.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
The Clevite / Mahle are advertised as narrow on one side for large fillet radius:
https://catalog.mahle-aftermarket.co...52599445131138
Ken,the bearing looks fine,did not take a close look at the F&R thrust side of it,will take a look next week.The only bearing that looked bad was the rear main.Tom
Thrust bearing
Just a thought, were the bearings supplied by Butler with the rotating assembly? If it is a journal radius issue wouldn't some culpability belong to Butler?
For the spark plugs, is it possible the center electrode broke inside the insulators and dropped down to close the gap? Crazier things have happened.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
In my opinion, they should sell the kit with a narrow bearing or reduced radius (fillet). The customer should have no need to machine the crank for this. At the least, send a note with the kit that this needs to be checked. Also, I wouldn't be surprised if this is either a manufacturing defect by Scat or Clevite. I doubt Butler would even check something like this on their own builds, This cannot be a normal thing, otherwise garage hobbyists are doomed. If a hobbyist needs to go to this level of inspection detail on semi-finished parts, it becomes an unworkable project for most of us. Moving forward, I would caution anyone against purchasing their own parts and doing this. Let your machinist prepping your block purchase the parts and have responsibility for them.
I can't physically do the work on these big engines anymore so if I am doing something it needs to be done right the first time and if I'm pulling an engine, it better not be because I screwed up. Machining\manufacturing defects are not unheard of, even with quality vendors and suppliers. If we need a near clean-room environment to assemble an engine, that's going to put a hardship on a lot of people who don't have access to that kind of resource. |
I had a block honed, looked great, fitted mains, dropped in crank. Tightened each cap and checked the rotation torque. Excellent. Until I got to the last (rear) cap. It would not budge! I checked the clearances again, perfect. Except I never checked that little piece on back of the cap. ![]() When honed, the operator did not run the hone all the way through the cap/block. Did the wide part, thought the bearing didn't go all the way to the end of the cap. (thought they were seal grooves?)
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
While I completely understand this message. I think most of us buy these parts as time and money permits because of the cost. Is it better to to save the money, don't buy the parts and plop it down to a builder? |
https://www.instagram.com/p/CEzMqmjnCEc/ |
Just because a builder supplies the parts, builds it and you blow it up a day later later doesn’t guarantee squat. Too many variables. I like to run em on the Dyno before install. Much easer to repair a problem found on the dyno. At least I have a chance at knowing it Might hold together AFTER I install it. How long it will run after install is still a crap shoot on even a moderately built Pontiac. I drive em hard....
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
IF we took the job , it was made clear, in writing...no warranty. I would offer to match their “Summit Racing” pricing. |
Those dowel pins have anything to do with the failure?
None at all,the block was line honed after they and the ARP bolts were put in.Pretty sure its something to do with the radius on the aftermarket crank and the bearing.Tom
Weird.... So you’re thinking it’s a manufacturing flaw? Those scat rotating assemblies are usually darn nice.
What was the mfg of the bearings? I had a two sets of Clevite bearings here last year and one set was almost .018 wider than the other. I started checking all of them I install now and also radius the sides of all the bearings with a hand debur tool.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 Last edited by Mike Davis; 09-18-2020 at 09:05 PM. |
Clevite also. You are more observant than me. Smart move.
Was the rear seal already taken out before the pic?
Or a camera shadow thing? The heat also seems to be quite a bit forward of the slinger radius enough to turn blue in the oil groove. Seems if it was as simple as bearing riding slinger radius it would clearance itself quickly on break in then cool and would also affect end play on assy I once burned a rear main bearing I suspected it was from a -8 oil line ( to small ) to cooler / filter on a long high speed run went to -10 15 years before interweb .
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 09-18-2020 at 09:26 PM. |
