Old 03-29-2023, 01:03 AM
dataway's Avatar
dataway dataway is online now
John, that is what is called a "Resin Printer" ... it uses a liquid resin which is sensitive to UV. A UV beam is focused on it one layer at a time to progressively harden the resin into the desired shape. They make very nice detailed prints, but only really suitable for non-structural parts, figurines, toys etc. in most cases. Can also be used for creating casting cores for casting intricate parts.
https://en.wikipedia.org/wiki/Stereolithography
I use what is called an "FDM" printer, Fused Deposition Modeling printer.
https://en.wikipedia.org/wiki/Fused_...nt_fabrication
The two processes are similar in concept, totally different in application. Resin printers are a bit of a mess to operate, liquids, smell, cleaning the parts, curing with UV light etc. My FDM printer (https://www.amazon.com/s?k=creality+...s_ts-doa-p_1_7) sits right behind me while I sit at my computer desk and I let it print, reach back and pull off the part when it's done.
If you want to get started in the hobby, I've had great luck with the one I bought. Week or so learning curve, they can be much like tuning an engine as far as tweaking settings, but well within the capabilities of anyone with mechanical skills. Most people have more problems with the software to generate their own designs than they do with the printers themselves. The defacto standard program for designing your own parts is Fusion360 by Autodesk, free for non-commercial use and VERY capable CAD software usable for far more than just 3d printing files. Fusion360 is also widely used by the CNC world as it can generated g-code for many, many CNC tools.
I use Autodesk Inventor, the big brother of Fusion360, which is a full featured CAD program used by many manufacturers, which has an equally large learning curve.
A 3d printer is basically a machine tool, it uses g-code just like any CNC machine, it just ADDS material rather than SUBTRACTING it ... which is why it's called "Additive Manufacturing".
Feel free to bombard me with any question you have concerning 3d printing.
  #162
Old 03-29-2023, 06:28 AM
Thanks!
  #163
Old 03-29-2023, 02:08 PM
dataway's Avatar
BTW, many, maybe even the majority of 3d printer users don't get involved in the design process, they just download the model files and print them.
To be honest the consumer 3d printer market is still dominated by people printing toys of some kind. People designing and printing their own parts is probably only 20% of the consumer market. So there end up being a lot of people that are very good at printing things, but no idea how to design something themselves.
Then there are the guys that are better at designing than printing (like me).
Point being, you don't have to be a CAD expert to get into 3d printing, but most mechanically inclined people want to start designing their own parts in short order.
  #164
Old 03-29-2023, 02:40 PM
Shiny Shiny is offline
...The defacto standard program for designing your own parts is Fusion360 by Autodesk, free for non-commercial use and VERY capable CAD software usable for far more than just 3d printing files. Fusion360 is also widely used by the CNC world as it can generated g-code for many, many CNC tools....
I toy with learning CAD but have not found a "free" set of tools. As I understand, I can get a free trial of Fusion360 but after that, I pay.
If I took a class at a local community college, I suspect I'd have better luck.
I have played with "FreeCAD", but have not invested any time to really learn it. Is it useful for basic part design or too limited/awkward?
Mike
  #165
Old 03-30-2023, 01:40 AM
dataway's Avatar
You can get the free "Personal Use" version of Fusion360 here:
https://www.autodesk.com/products/fusion-360/personal
I've been using it on and off for quite some time now. It's partially cloud based, meaning an online connection is required for some processes, it has some handicaps made in when it comes to file conversions, shouldn't be an issue for a casual user. Upside is it automatically updates on the fly, Autodesk releases new capabilities and adds them to 360 for the general public to test.
Most of the open source type free cad packages like FreeCad will work on similar principles, from the look of their website it looks pretty capable. As long as the software will output STL files it should be a decent starting point.
  #166
Old 04-08-2023, 10:30 PM
Held for Ransom's Avatar
Had one made up the way I thought it should be. I wish the lines weren't there. I'll look at it closer...
ID:	610440   Click image for larger version
ID:	610441   Click image for larger version
So long, farewell.
  #167
Old 04-09-2023, 03:16 AM
dataway's Avatar
Looks very nice and fit looks great. The whole reason for using the "insert" piece is that you can print it flat and pick up the texture of the build plate rather than seeing the printer lines. Much like a cookie picks up the texture of a cookie sheet.
  #168
Old 04-12-2023, 06:07 AM
cnc's Avatar
cnc cnc is offline
I have one coming this weekend …my son made it then painted it with a paint they have similar to trunk bed texture, hope it fits…..
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #169
Old 04-16-2023, 02:31 PM
cnc's Avatar
cnc cnc is offline
Here is the plate just laying inside the cutout….I painted it but I think I’ll redo the texture again has a couple of nics in it…and knock down the sheen….but fits perfect…
  #170
Old 04-16-2023, 04:31 PM
dataway's Avatar
Sweet ... is that one that your son printed? Looks like a nice job.
  #171
Old 04-16-2023, 06:03 PM
cnc's Avatar
cnc cnc is offline
Yep….turned out great…..like I said couple nics in it weren’t in it when he showed me the first pics no biggie though love it
The Following User Says Thank You to cnc For This Useful Post:
  #172
Old 01-22-2025, 05:46 PM
lrust's Avatar
lrust lrust is offline
I had a CAD drawing made of radio delete plate for 67 GTO. Is there anyone here that will print a couple for me?
  #173
Old 01-22-2025, 07:52 PM
dataway's Avatar
Irust,
PM me, and I'll give you my email address and you can send me the file. If it's something I can print I'll let you know.
Bear in mind the print would only be as good as the CAD file, it took several iterations to get it right in our previous attempts and I had an OEM example to work with.
Would be pretty amazing if it actually worked on the first attempt. Were the pins in the back (or however it is retained in the dash) modeled in the CAD?
  #174
Old 01-24-2025, 03:01 AM
dataway's Avatar
Irust .... I emailed you.
