#1821
My car has this setup and was optioned with A/C, rear defrost, PW, PL and power sunroof.
Home of WFO Hyperformance Shaker induction. |
#1822
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
#1823
I think there are a few different castings of these repro'd. One version I know of has the casting numbers ledgible on the pass side due to a shift in the mold. Other than someone knowing the numbers cast on the repro's, another way to tell is the originals are extremely thin walled making them very suseptible to cracking. The repro's along with being thicker walled were made of a more mallable steel.
#1824
Thanks John and Larry on the adjustment/idler pulley answer! My 1974 SD Trans Am does have AC but not all of those other options so no 80 AMP alternator. This TA did not have the adjustment/idler pulley when I purchased it and everything else looked so original I could not imagine that this pulley would be the only part missing. Also, that SD Trans Am that I sold Lloyd did not have this pulley either.
Now, I have the pulley and you said that the alternator had a different bracket also. Do you have any photos you could post showing the pulley setup and the alternator bracket? I will see if I have the other matching brackets to put the set together.
Gary |
#1825
Try this:
#1826
That diagram is excellent. Thanks John!
Gary |
#1827
Will we have a forum by page 100????
(the HO thread's been up top too long. ;~) |
#1828
Youssef, the car looks like its moving right along.
There are a few things that where not on the car when it was dipped. Seat belt bolts, punch caps, and a couple of those cables, but all of them can be touched up later by hand(if needed). Keep the pictures coming, Brew |
#1829
Thanks Brew,
Any commnets are Highly welcomed youssef
74 Super Duty White 73 Super Duty White Looking For Formulas SD 73 / 74 |
#1830
More pictures please!~
#1831
I'll pass by the shop this week and take more pics
thanks Youssef
#1832
Hey Guys, just purchased a 74 trans am 455sd and am begining a rotisserie restoration. I am looking for direction on a proper restoration for originality. Currently I am most concerned about the body and finishes, who can I talk to that can help? Are there any other sources out there?
thank you, Bryan |
#1833
Ask away! There is a ton of resources right here.
Welcome to PY and the SD Forum thread. What is the color combo of your car? Auto or 4 speed? Pix?
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
#1834
Thank you,
The car is all original and complete plus I got it from the newphew of the original owner. White/Blue automatic. The only thing I am missing is a carb, anyone have a numbers correct carb? I will post photos later. Bryan |
#1835
ask away, this is the forum
#1836
look for #7044270. a toughy to find. good luck with the search. seems there are a few blue '74 cars here. |
#1837
takid455
I believe his car is white with the blue interior. The carbs show up from time to time and they are expensive, like 2k or more depending on condition. Sure glad I don't need one for my 4 speed. OUCH!
#1838
you are lucky if you can get it for 2k
thanks Youssef
#1839
Thanks guys for all the respones. I have attached a photo of the car when I got it. Now it is in pieces.
One question I have: is the carb date stamped to match the engine or body build date? I understand that the carb is stamped to match the year of vehicle and whether it is automatic or manual. So are there more stampings to match the build date or can I get a carb that is from 1974 with an auto matic trans. One thing the seller told me is that his uncle bought the car and ordered a 1973 455sd t/a with a manual trans at the end of 1973. The dealer came back and said he could not order a manual trans with a 310hp motor. So this car is supposed to be a 310 hp 1974 auto trans car. Could this be possible? How can I tell? Since I am in CA, we can only use certain materials on the car. We have to use water based paint now. Should I try to get around that? Does the entire body get red oxide? Where can I get Engine paint/color? Dash/Interior Color? Trunk color? Is there anything that need to beaware of when repainting the black semi gloss? What should I mask off? Thank you for all the help. Bryan |
#1840
Oh, I did order PHS documentation I will share that when I recieve it. The car is fairly basic.
Bryan |
