Old 09-02-2023, 06:23 PM
64speed's Avatar
64speed 64speed is offline
I drove it more today and it did it once pulling out of the driveway. I crawled all around it and there is a witness mark on the swaybar so I’m gonna put it on the lift and see what I can do about it
  #1822
Old 09-03-2023, 11:43 AM
The Champ's Avatar
On my '64 the contact point was the front bottom corner of the wheels well. This was with 235/60/15's (26.1" tall) on 15x7" rims with 4.25" BS and front disc brakes. Just took a little tweak to the left front fender.
Running 215/55/17's (26.3" tall) now on 17x7" rims with 4.625" BS without any problems.
  #1823
Old 09-03-2023, 06:57 PM
64speed's Avatar
I found it. Sway bar end link on the drivers side is bent. Easy enough
  #1824
Old 09-17-2023, 08:09 AM
64speed's Avatar
Do coil springs settle? I mean I know there has to be some settling but I have noticed as I have driven more and more the front seems to be sitting lower and I am getting light scrubbing on tight turns. Especially backing up.
  #1825
Old 09-23-2023, 05:19 PM
64speed's Avatar
Well I had my final abdominal surgery on Thursday so after about 6 weeks I’ll be back at it. If my wife’s confidence on doing the interior pans out then all that will be left for the forseeable future is the headliner. I am pretty stoked.
The Following User Says Thank You to 64speed For This Useful Post:
  #1826
Old 09-23-2023, 09:00 PM
Gach's Avatar
Gach Gach is offline
I like that sticker, my 64 GTO I bought off a guy had a 421 motor in it. With that sticker, it was a real Royal Bobcat 421 motor. Good luck with your recovery. Hang in there.
  #1827
Old 09-26-2023, 09:26 PM
64speed's Avatar
Well the car has been sitting 6 1/2 days which is the longest it’s sat since I’ve gotten it running. I can’t drive right now but I decided I’d go see how easily it would start. Hit the accelerator to set the choke and after about 5 seconds of cranking it fired right up. Sat for a minute and listened to some tunes and then went back in the house. I will be able to drive again in about another week. Getting carpet for my bday (Oct 24th) which I will install and my wife feels confident about the door panels. If I can get all that done I will almost have a complete car minus headliner.
  #1828
Old 09-26-2023, 11:02 PM
Gach's Avatar
Listen to some tunes NICE !
  #1829
Old 09-27-2023, 04:11 AM
64speed's Avatar
Yeah man I gotta have music. I had the factory radio converted by turn switch to everything including hands free calling. 4 6x9 speakers ( two in the package tray and two 5 way in the original kick panel vents) all powered by a Pioneer 1000 watt amp.
The Following 2 Users Say Thank You to 64speed For This Useful Post:
  #1830
Old 10-04-2023, 11:02 AM
64speed's Avatar
I am gonna try to do the door panels myself. I have dome carpet many times before so that is no problem. My door panels have the templates on the back as to where to cut for the door handles and such but they are totally smooth and have no indicators as to where the clips or screws that actually hold them on go. Do any of you guys know of any videos or if you could give me some guidance that would be great.
  #1831
Old 10-04-2023, 11:13 AM
HWYSTR455's Avatar
Do you have the originals still? You could use them as a template.
  #1832
Old 10-04-2023, 11:33 AM
64speed's Avatar
No those things were rotten and long gone.
  #1833
Old 10-04-2023, 11:36 AM
HWYSTR455's Avatar
Take a piece of wrapping paper or shipping paper and hold it up to the door, create a template.
I'm sure you can figure it out, there's many ways to do so.
  #1834
Old 10-04-2023, 12:43 PM
Collectors Auto Supply has the inner door insulation panels; these can be used as a template to locate all the screw holes and attaching points. Most of the interior guys I’ve known over the years use luan plywood (1/8 to 1/4 inch) because it will flex and is relatively inexpensive. To recreate the pleats in the door panels you are going to need different thicknesses of foam of differing densities, along with the tools to embed the vinyl onto the foam. I understand why you’re doing this; the estimates for replacing the door and rear seat panels for my Catalina nearly gave me a heart attack.
Dr. Thomas Sowell
  #1835
Old 10-04-2023, 06:12 PM
HWYSTR455's Avatar
Are they preassembled door panels? Do you have pics?
  #1836
Old 10-04-2023, 06:41 PM
64speed's Avatar
Yes they are preassembled. I just don’t have any instructions for the clips
  #1837
Old 10-04-2023, 08:18 PM
MUSLCAH MUSLCAH is offline
So who ended up painting it ?
  #1838
Old 10-05-2023, 12:23 PM
64speed's Avatar
KMA customs in Tampa
  #1839
Old 10-07-2023, 08:23 AM
64speed's Avatar
Ok carpet is going in this week. I installed the shifter hump a while back. Not sure it’s in the right place but I just self tap screwed it down so it can be moved if not. May have to enlarge the small round hole the shifter comes thru but no big deal. So what do you guys do to shield the carpet from the water that would spray up thru that hole? I have everything painted and rustoleum applied thoroughly to the hump but I don’t want water coming thru that hole and soaking the back of the carpet.
  #1840
Old 10-07-2023, 09:56 AM
gtospieg gtospieg is offline
You need a rubber boot
