Old 08-21-2021, 02:18 PM
wreckmastr's Avatar
Originally Posted by 67Fbird View Post
if you two need to go get a room...please do so.....otherwise get the hell off of the OP's thread about building serious chit....not bitchin and complaining about who's ego did what when....
Is this intended for me? My post was to the OP.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #1922
Old 08-21-2021, 08:33 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by wreckmastr View Post
What is the RPM at the top of 2nd gear and what's going on motor doesn't seem happy?
Hit the rev limiter, was set to 8500rpm.
Name:	raven datalog rev-limit.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1923
Old 08-21-2021, 09:53 PM
mgarblik mgarblik is online now
I was going to say rev limiter or valve loft/bounce. But I didn't want to be wrong. Car loves to rev, that's for sure. Full of potential.
  #1924
Old 08-23-2021, 07:46 PM
cgeise's Avatar
cgeise cgeise is offline
I am seeing about 700 drop on the shift ??? not terrible
  #1925
Old 08-23-2021, 08:21 PM
wreckmastr's Avatar
I cant really make out in the pic what the numbers are but it looks like a lot more than that IMO. Maybe Ed can tell us what it is.
6.98 @ 199mph
4.53 @ 164mph
  #1926
Old 08-23-2021, 10:34 PM
RAIV-Z's Avatar
1-2 shift shows ~700rpm
2-3 shift is ~1200rpm. AFR was fat after the shift until closed loop re-enabled. I leaned out the upper RPM range by ~5%. CL Correction prior to doing that was a little over 10% in the 7500+ range.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1927
Old 08-24-2021, 02:30 PM
cgeise's Avatar
once you are close -- get rid of the closed loop altogether -- and tune it a little at a time via the fuel map --
The Following User Says Thank You to cgeise For This Useful Post:
  #1928
Old 08-25-2021, 08:43 AM
Always trying to learn a little more about aftermarket fuel injection. What is the advantage of NOT using the wide band O2 as the tune gets closer to optimal? Does it give you the ability to go a little richer than the closed loop control will allow for more safety and power? Thanks for the education.
  #1929
Old 08-25-2021, 10:48 AM
Tom Vaught's Avatar
Boost Engineer
Ideal is to get the calibration "dead on" for most of the calibration (I believe what cgeise is referring to) and then let the Wide Band make small corrections where a false correction (if the Wide Band is contaminated) will not harm the engine.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
  #1930
Old 08-26-2021, 10:19 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
Only advantage of a wide band (depends on application here...he's boosted so alot more variable) on just a NA vehicle is it certainly allows you run an out of tune vehicle SAFELY, WHILE you tune up your maps.. Most of the self learning stuff is just a loop program to tighten the margin of error/adjustment....over and over again until XXXYYYY stoichiometry is dialed in.. My dinosaur commander MPI system had no self programming, NO self learning and was very challenging to tweek.
  #1931
Old 08-26-2021, 01:59 PM
charlie66's Avatar
For the self learning and corrections to work right, the Target A/F map that it reads off of needs to be right .
My Half AN Injun.....
  #1932
Old 08-29-2021, 09:17 PM
RAIV-Z's Avatar
Only managed to get in one pass today, unexpected rain came in and the event was canceled.
Name:	2021-08-29 12.25.42.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1933
Old 08-29-2021, 09:21 PM
opeliac opeliac is offline
Good pass...Why do they keep saying "partial" pass on the FB posts?
  #1934
Old 08-29-2021, 10:03 PM
RAIV-Z's Avatar
I was off the throttle before the end of the run.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1935
Old 09-01-2021, 11:39 AM
cgeise's Avatar
the big cams on a race motor tend to confuse the self learn a bit -- it will get you operational but from there just read your O2 and the plugs and adjust the fuel map and timing as needed -- when tuning a race car the upper right side of the fuel map is about all you need to worry about for the most part --
  #1936
Old 09-01-2021, 07:47 PM
We are finally getting a new chassis dyno at my school. The old one, A Mustang Dyno, was a cast-off unit from a failed Ohio EPA emission testing program in the early 2000's. It was also limited to 400 ft. lbs at the wheels. The new replacement will handle 1200 Ft. lbs and have wide band capability and of course 20 year newer software. Very excited to get into tuning these EFI race cars. Should be fun.
  #1937
Old 09-01-2021, 08:32 PM
cgeise's Avatar
for what its worth -- when we tuned on a dyno -- it still needed tweaking when on the track -- I thin the track loads it down diff than a dyno -- at least that's what I was told.
  #1938
Old 09-01-2021, 09:19 PM
Tom Vaught's Avatar
Boost Engineer
That is an accurate statement, as we would get a good solid calibration on vehicles on the chassis and Engine dynos, AND STILL NEED TO FINE TUNE on "On the Road" and in given "Track" (parts of the country), conditions, etc. The dyno gets you about 85% of what you need. The Track gets you another 10%. You never get the last 5%.
Tom V.
  #1939
Tom Vaught's Avatar
Boost Engineer
Tom V.
  #1940
Old 09-02-2021, 07:24 PM
67'7F6'Bird's Avatar
Ed Page's RAVEN is in the Customer Car Spotlight in Stroud's September Newsletter.
The Fastest 'All Steel' 69 Firebird STREET CAR on the Planet.
POWERED by PONTIAC! Twin Turbo DCI Ram Air V Headed Indian Adventures Block, Solid Roller Cam with Holley Direct Port EFI.
See you all in the 6's soon.......
Be Safe with STROUD SAFETY PRODUCTS. ~We are STROUD SAFE!
Click the below Link to sign up for their Newsletter.
https://stroudsafety.com/
Name:	Raven Newsletter.jpg
