New best
The local track opened for a test and tune today and the air was really good.
DA was 410’ on this pass which is about as mineshafty as it gets around here. All 4 passes were between 10.602 and 10.672. Dead calm with no wind to speak of. Previous best 10.70 last fall was at 50’. The staff did an excellent job all day prepping the starting line and keeping it glued down as they usually do there. Staged at 1600 and shifted both gears at 5500 on all runs. Have gone higher in the past but it runs about the same if not slightly slower shifting up near 6k. Timing was 38 total, my Quickfuel based mash-up Frankencarb 950 was jetted 80/88 with a PV up front, 28HSAB’s and 73LSAB’s and 40/40 squirters with 50cc pump and brown cam in no.1 up front and 30cc with blue cam in no1 in the back. Drove 120 miles round trip and got 8mpg,barely. Left with a full tank and came back with a 1/4.
The Following User Says Thank You to TCSGTO For This Useful Post: | ||
Congrats!
'65 Tempest 467 3650# 11.30@120.31 |
Nice time slip, and great 60 ft. Track prep is everything in the colder weather, nice u got out may be one of the last outings . Impressive to rip those times and drive 120 miles . Smiles per gallon....
Congrats!
Nice pass! This late in the year getting any pass up north would be nice.
Congrats!
No doubt, they always do a nice job there getting things ready even for test n tunes which is unusual at a lot of tracks these days.
Made 4 passes. All between 10.602 and 10.672 and 60’ times between 1.45 and 1.48. The variance was probably from me doing something slightly different and not the car or the track.
Nice!
I agree... tough getting good air AND good track prep on the same day
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
Thats a fast true street car, congratulations. Do you put some slicks in the trunk or drive out on radials and let her rip ?
Congrats on the new best. Great 60' time. What converter are you using?
I’ll take them off for the winter and keep them inside in plastic bags in the basement.
It is looser on the street than one of Continental Jim Hand models but you can still feel the shifts. This one I had built probably leans more toward the strip than street but isn’t bad at all around town. It’s definitely tighter at low speeds than a Continental 10” 4400 stall I had tried in the past.
Great looking dash!
Great 1/4 mile dash ! Now lets talk about an OVERDRIVE... |
That's a real street car.
Impressive 60 ft. That is the 517 - correct? |
X2, Congrats. You're an inspiration to my '68.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
Very nice! My first GTO was a 68.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Awesome..good to see those convertors working well.
That's one of them 10 second street cars I heard about in "The Fast and the Furious."
Awesome!
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Congrats on the personal best and REALLY cool car! Very impressive that you drive it to the track and great combo!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I see your in Ohio what track are you at?
Sounds like a perfect day to me. I'm jealous about your 60'.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
