Old 03-03-2024, 12:43 PM
Singleton Singleton is offline
Originally Posted by Scott Stoneburg View Post
Pretty sure Mr Gasket still offers them, just not cheap
The problem with the Mr Gasket 987G 2-degree cam key is that it changes the crank degrees by 4. So if you're wanting to advance or retard the cam 2 degrees, you would need a 1 degree offset cam key, which, as far as I know, no one makes anymore since the Mopar keys are out of production.
The Mr Gasket 988G 4-degree key will change crank degrees by 8
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following User Says Thank You to Singleton For This Useful Post:
Old 03-03-2024, 02:04 PM
Formulas Formulas is offline
https://s1partscenter.com/brands/cummins/key/3944039
from the pictures and what little specs i can find .. this key seems to have minimal offset
some mercedes engines have the same dimensions but with a large offset
in the past i have measured my mopar key set and it seems that every step in offset is around .010 of step increase
Old 03-03-2024, 03:07 PM
I'm talking about CAM Timing, not ignition Timing.
Bill Nye.
Old 03-03-2024, 09:29 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
My machinist hand made one with a file to get it right on one motor he assembled for me. I usually am maybe 1 degree off using the Mopar ones. Have yet to find a chain right on dot to dot.
Skip Fix
