1964 Tempest ready for you finishing touch
http://cgi.ebay.com/ebaymotors/1964-...item3a64d77851
Q-JET TO MANIFOLD BOLT KIT 4-CORE RADIATOR MTG KIT CONSOLE SHIFT PORCH SHIFT PORCH SCREW SET SHIFT BOOT W/O CONSOLE SHIFT BOOT TRIM PLATE SHIFT PLATE SCREW SET PRESSURE PLATE TO FLYWHEEL BOLT KIT FLYWHEEL BOT SET THROWOUT BEARING BORG & BECK PRESSURE PLATE/CLUTCH HIGH OUTPUT DISTRIBUTOR KIT PYPES PERFORMANCE Exhaust System, Race Pro, Header-Back, Stainless Steel V8 BATTERY BOX RECONDITIONED 1964 GTO HURST COMPETITION SHIFTER, BENCH SEAT CORRECT PROFESSIONALLY REBUILT Q-JET CARB NEW REBUILT 389, WITH 4X HEADS. HEADS HAVE BEEN MACHINED AND CHECKED FOR CRACKS. MILD LIFT CRANE HYD CAM ENGINE WILL NEED TOUCH UP WITH PAINT, AS IS WAS SET IN CAR AND TAKEN OUT TO TEST FIT HEADERS, AND V8 MOUNTS NEW 4 TUBE HEADERS NEW SHIFT PORCH FOR 4SPEED NEW SHIFT BOOT, WITH CHROME RING NEW CHROME VALVE COVERS NEW CHROME AIR CLEANER NEW GOODMARK FLOOR PANS INSTALLED BORG WARNER SUPER T10 4SPD OUT OF CORVETTE CAR WAS ORIGINALLY 215 6CYL WITH 3 ON TREE CAR HAS 66,000 ORIGINAL MILES CLEAR TITLE We are expecting a new baby, and unfortunately this project isn't in my schedule anymore. Everything needed to put the car back together, from bolts,pulleys, chrome rockers,chrome door sill plates, etc is going with the car. All you will need is your own personal touches and some incidentals, battery, fluids...etc. Will need new carpet. Tires are in great shape, also comes with all new brake pad kits. |
updates and links to more pictures available at http://cgi.ebay.com/ebaymotors/ws/eB...m=250799945809
sold
