Old 07-01-2020, 10:00 AM
LPI's Avatar
LPI LPI is offline
Default 1964 GTO two door post coupe - 4 speed
1964 GTO two door post coupe four speed car.
The car runs and drives great, at the moment probably the most fun car to just slide in and fire up and grab some gears like the 80's and 90's!
Car has been in a climate controlled car collection since 1994, since that time it has been driven about 40 miles per year, started and maintained over this time period. I put a new battery in it in May.
I have PHS documentation on the car:
64 two door post coupe 64-2227 02B KC
Paint code LL Interior trim 214
Acc: E2LP 3K 5NW
It currently has a 1975 Pontiac Trans Am 400 with an early stock intake and a holley 600 carburetor with a points style distributor.
It has a 65/66 Muncie four speed transmission and a Chevy 12 bolt rear end.
I have which goes with the sale of the car a complete in the crate a 1964 GTO 78XW engine with a 1964 GTO Tripower with the gen I mechanical linkage.
I do have another 64 GTO Tripower, each unit has different carb bodies according to DB, the the Gen II mechanical slide bar linkage which was purchased from Ames. I will be posting this 1964 76XW engine, Tripower and factory vacuum canister in the parts for sale section also so which ever sells first they get the pick of which tripower set up they want.
I also have for this car a 1964 single four barrel intake and carburetor.
The car retains the factory original 1964 GTO shifter.
Also with the car I have an original 8.2" 10 bolt out of a 1964 lemans.
I will entertain the option to sell the car and the 78XW engine separate ONLY if the car sells first.
If you have any questions give us a call or drop us an email. I can email the PHS if you need a copy.
Car and crate engine $32,000.
414-530-twenty seven 04
info@luhnperformance.com
Name:	1964 GTO post coupe.jpg
ID:	543910   Click image for larger version
ID:	543911   Click image for larger version
ID:	543912   Click image for larger version
Name:	1964 78XW engine in crate from CA.jpg
Holy cow Tom that's a dirt road...
www.luhnperformance.com
Old 07-01-2020, 10:43 AM
tom s tom s is offline
Nice crating job!Tom
Old 07-01-2020, 11:35 AM
LPI's Avatar
LPI LPI is offline
Thanks Tom!
Wisconsin 53154, sorry I left out the location in the original ad.
