Here we go again
Well ....
Looks like I'm pullin the engine again.....sounds like I've developed a Rod knock engine Oil pressure is good 20-25 at idle... Noise starts at about 2200-2300 ,,,,, Had Torquewar listening to it with stethoscope sounds like cyl 2 or 4 reving in park... Driving down the road starts about 55-60 MPH underload Wont be doin this till Dec...hopefully no significant damage.......wish me luck....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Just double check flexplate bolts before.
I did grab a hold of the converter/flexplate and tried to see if it moves and she doesn't,,,
Doesn't hurt to double check though....thanks
Which pump and what bearing clearances?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
are you running a mechanical fuel pump?
Melling oil pump m54d ( 9/16 check ball shimmed spring )
Clearances sorry...bottom end was done by reputable shop recommended to me in the area known for building some pretty stout stuff
Yep....stock unit...but the noise if definetly from the pass side not drivers side frt...near the pump
Put a bar to the front pulley & check to see if you have to much end play , as it might be to much clearence in the thrust bearing causing the knock. I had an engine once that had an intermitten knock that was the thrust bearing when I got it apart.
Thanks will check that as well....
Sounds like it is going to be a Rod-pair huh. Had a similar plight, thinking it was due to oil-starved operation during break-in while driving, and not believing the low gauge readings.
Fingers crossed......
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Bummer
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges 1973 Formula 4spd long term project |
More to check...
Hey Chris,
Sorry to hear that you are contemplating pulling the "devil" motor again. Before you do, check the balancer bolt torque, balancer fit on the crank nose & key-way fit, and to see if it has separated or come apart at the hub.
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
If you find that the rod bearings for those 2 rods do not snap in any more than you where detonating in those cylinders.
An audiable knock assures prying-out huh.
My 400 has also developed a slight knock when warm. Right hand side from what I gather. Looks like it will have to come out again. This time I will have all of the rods resized then hopefully get the 428 done and in this car.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
Damn Chris, I'm really sorry to hear this considering what you've been through with this engine.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Pulling a plug wire is a good indication, if it's a rod knock, it most of the time will go away.
Just the opposite, the bearing shells will fall out without any assistance .
The Following User Says Thank You to wheelspin For This Useful Post: | ||
I was gonna do this as one of my checks
