Intake manifold 9794284?
Looked on a few Pontiac related sites to check this intake #. Appears there is a 97942”3”4 listed. Is there a 97942”8”4 or am I just seeing it wrong? Whiich is correct for a ‘68 350HO? I have a 9790140 on it which I believe is original because it’s a numbers matching drivetrain. It a Arlington build.
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
The 140's were early production 68 intakes before they switched. like made in late 67. I can't remember the change over date offhand. what's the date code on it and the build date of your car?
9794234 first appeared at the introduction of the RamAir II engine mid-may 1968 on all Pontiac V8´s and were also used on all 1969 engines except RAIV.
The Following User Says Thank You to Kenth For This Useful Post: | ||
In my search for a replacement date correct intake I noticed the 140 to 234 change over casting date was approximately March 16 or 17 of 68.
The original cracked '234' manifold was dated D108. I luckily found an excellent D118 replacement. My 68 is a 05A build with a WT engine.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Amazes me that the 0140, 4234, 068 manifolds were designed "just right" for 350 thru 455.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
