Tri-Power Tech 57-66 Tri-Power Talk
Old 10-15-2018, 05:38 AM
avman avman is offline
Originally Posted by Geoff View Post
Yes, that pipe sealant is brilliant stuff. Just make sure you apply it to the second thread & back, not the first thread, to avoid any getting into the needle & seat.
Yes. Per the instructions, skip the threads at the end, I applied the sealant about 1/3 way from the carb end, but I did go all the way around the fitting instead of the recommended 3/4 turn.
  #42
Old 10-15-2018, 05:54 PM
Yep, that is what I did. The stuff works great so far, and it is made for that per the packaging, along with some other specific, important duties like brake fittings.
  #43
Old 10-18-2018, 10:21 AM
My wife is taking the GTO out solo today to pick up some friends from out of town who are visiting. The LocTite sealant is working fine so far, and running better since I turned both center carb idle mixture screws out a lot.
There's a handheld fire extinguisher in each of our 2 classic cars, but I am impressed with the LocTite so far, and when I send the Rochesters out to Dick B. for additional modifications, I will get the fuel fitting threads fixed then.
  #44
Old 10-18-2018, 11:47 AM
tom s tom s is offline
How is her life insurance?LocTite product liability insurance?Fire insurance on the car?Tom
  #45
Old 10-18-2018, 02:43 PM
Life insurance, check
Car insurance, check
Current status of LocTite product (see pic) LocTite is the white product where the brass fitting screws in.
As leak free as the day after I applied it.
Until I can get the carb fitting threads repaired, I don't believe that the LocTite product is going to fail.
