Looking for shifter rods/linkages for a full size set up. Also looking for pedals and a trans hump.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
I may be able to help you with the pedals. I have a set with bracket from a 1968 Catalina. I recall checking my Pontiac parts catalog when I pulled the assembly from the car. It should fit at least 1967-70 full-size Pontiacs. Email me at herbslegacy(AT)sbcglobal(DOT)net if you would like more information.
Thanks, Olmanwinter |
63gpman, I am glad I could provide you with some needed parts. I appreciate your clear, timely correspondence and prompt payment. I would work with you again anytime. Thank you for a great transaction!
Best regards, Olmanwinter |
It was my pleasure. I would have no issues working with you again on any items and to those that need parts from you, they certainly get my recommendation.
Thanks again!!
Are you still needing a shifter and rods?
Practicing social distancing for 65+ years |
I have a shifter already but need the rods. I'll send you a msg.
Brad! please tell me that you aren't putting a stick in that '67 Safari!
![]() Quote:
How likely is it??? Not very, but I am sure I can use these parts down the line on some other full size that I am likely to acquire!!!!
Man, I hope you keep that car as-built.
If I were to say what my biggest issue with my car addiction is that I always have 100 projects going on at one time either in my head or in process. I buy parts, sell, keep some sell others, buy some for a future project, change directions, sell those parts, buy some back again and so on.
I call it C.A.D.D or Car Attention Deficit Disorder.
I have some odd ball linkage for a stick & not sure what its for , but it doesn't look like it's for any A or F body cars as I know what they look like so I may have some parts for you to.
Here are what the linkages should look like.
Try this "transmission" guy. He comes to Norwalk. Good guy to do business with.
D.M.E. Dennis C Maroudas 625 Forest Hills Rd Forest Hills, KY 41527 (606) 237-6648 |
![]() Quote:
Have linkage rods with their shift levers-$150
I have a floor hole template that I cut out of a 4 speed car many years ago, if you need to borrow it.
Have a complete set-up:Clutch&brake pedals, upper push rod, complete Z-bar and lower push rod w/frame bracket.If assy is purchased we also have the floor porch available.
Thanks for the offer. I am not needing 4 speed parts any longer.
