421 short block
I have the opportunity of purchasing a complete 65 421 standard bore short block for $1k. Is that fair market value?
I would say so, even though you will not use the pistons and rods if they are stock!
Those steel rods in those 421 motors are weaker then the cast rods!
Thanks Steve. Although I would go with an after market rod , wasn't aware that 65 rods are considered weak. Thought that was the 58-60 forging?
Definitely fair, probably closer to the lower end price wise.
Rods used in the 1965 421 is the same as used in all other V-8's from 64-79----
If it is a STD bore and the crank is good that is a good price. Should have a Armasteel Crank. Not as nice as a the earlier 990 forged but a good crank worth about $350-$400 itself.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
$1,000 bucks? I'd set a land speed record for my wallet.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
Some of the early 1965 421 motors where STILL using the basically steel version of the cast armsteel Rods, I know as I have taken apart not one, but two of the 370 hp rated short blocks and both of them where made as such!
I know, I was left scratching my head also! I think I still have the block production dates of those two short blocks in my info , I will look. The 990 Crank was only fordge for usage in the SD motors, and I can guarantee you that none, zip zero ever found there way into a production line 421!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 05-04-2021 at 06:43 AM. |
The 990 Crank was only fordge for usage in the SD motors, and I can guarantee you that none, zip zero ever found there way into a production line 421![/QUOTE]
Steve, what's so special about the 990 cranks? Didn't they still have the 3.25 journals with oiling issues? |
Where do I pick it up?!! Sounds like a good price to me!
"I know just enough to keep me here, but not enough to get me out" |
The cast rods as was said are all basically the same.
The rubber rods were the Forged Rods that were made from inferior steel and not heat-treated and machined like the 421 SD forged Rods. Those were offered for a few years in the early 1960s. Wide Forging line on the side of the rod. If you have a rod with a casting line on the side, like Mike Davis posted, then it is a cast rod and all the same basically for all engine applications. Even the Forged Chinese rods, many times, are better than those forged "Rubber" rods. Tom V.
Thread Tools | |
Display Modes | |
