Old 04-03-2021, 03:20 PM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
Default 64 Bonneville dash assembly
Does anyone have a copy of the dash assembly for a 64 Bonneville? My son has a 64 Bonneville convertible and we need to pull the dash and replace the wiring harness. TIA
Old 04-03-2021, 08:23 PM
If it doesn't have AC you should be able to change the harness by just removing the top of the dash. Remove the A pillar trim, remove the screws from the front of the dash pad, unplug the radio speaker and pull the pad toward you while lifting enough to clear the front of the dash with the speaker. You should be able to reach everything from either the top or the bottom.
Old 04-04-2021, 08:22 PM
Thanks for the info. It does not have AC.
