1970 GTO parts
4 speed Drive Shaft and Yoke Balanced
Rear Window Molding ( 4 pieces) Plastic Vin Window 70 Rochester Complete for manual Trans,. 4 Core Radiator Does not have to be a Harrison. Paypal payment only or I can pickup if in IL Message me with prices. Thanks |
does your car have a 12 bolt ?
also large or small out put on the tailshaft for the yoke ? I have a 69 4 speed shaft its original for small output and 10 bolt a sweet set of rear window moldings ,,,, a nice set and some singles is the window vin same as 69 ? I have a 69 ... spare I think I have a 70 service replacement 4 speed carb still no non original 4 row rads for sale,,, |
Hi Scott,
It is a 10 Bolt, unsure on the yoke. I will see if I can use the 69 shaft? You can Private message me the prices. I will have to find if the 69 and 70 Vin window are the same All I know is the Reproduction version is not good. |
The Rear Window Moldings are original correct for a 70
The Drive shaft goes to a standard M 21 Transmission which should have a standard Yoke
I would also be interested in the 1970 Rear Window Moldings Give me the numbers off the carb I would like to check that Let me know the prices. Thanks |
I'm still interested.
2 zero6 4six5 9165
Scott |
I am still looking for
Carb Radiator Full set of 1969 SeatBelts with Tags 4 spd Driveshaft Rear Window Stainless Trim Thanks |
Still looking for a 4 Core Radiator for 70 Ram Air 4 speed GTO
