Old 04-23-2021, 08:03 PM
jhein's Avatar
jhein jhein is offline
Default 4.88 gear!
So my car is in the shop having some things done, including the gear change. My guy calls me today and says it has 4.88 gears in it. He counted the teeth 3 times to be sure. That was a surprise. I thought it was probably a 4.11. Based on that I won't do the 3.08. Probably 3.31 vs 3.55. Now I need a new carrier too.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 04-23-2021, 10:21 PM
R 70 Judge's Avatar
My 70 Judge had a M20 and 3.55 gear and I thought it was a good compromise between acceleration and freeway cruising
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 04-24-2021, 02:44 AM
Formulabruce's Avatar
Not sure a 3.31 is available anymore. 3.42 is pretty popular.
Make SURE they Shim the front pinion seal OUT away from the carrier by 1/8" . Use a rod, or thick wire or make a giant 1/8 "washer. If they don't, it will leak. The seals now available are Not for this type of shorter nose housing.
If installed flush, the seal will not ride on the yoke shaft flat part, but rather on its front edge which has a chamfered edge.
(12 bolt only, includes GTO, Z-28, ETC)
Old 04-24-2021, 09:21 AM
jhein's Avatar
Thanks. I'll be sure to mention that. The guy working on the car is a custom car builder but he's sending the rear end out to a specialty shop for the rebuild.
Old 04-24-2021, 11:47 AM
Aus78Formula Aus78Formula is offline
Sounds like the perfect gear ratio for tree climbing
Old 04-25-2021, 01:06 PM
unruhjonny's Avatar
ok - I TOTALLY understand now why you thought the gearing was too high!!
you will probably be quite happy with the standard gearing that '70 Trans Am's received 3.55:1.
1970 Formula 400
Old 04-25-2021, 03:08 PM
Norwood's Avatar
Norwood Norwood is offline
JMHO. I’m very happy with my factory 355. I’d be careful telling the guy setting up my rear end how to do his job. I know what I would tell someone telling me how to do mine.
Old 04-25-2021, 05:19 PM
That said;, And respected, Better to only have to do it once. Learn from my mistakes.
Maybe print it out and put with the rear end so the builder can say "I caught this potential problem for ya"
Have seen MANY "mechanics" Disregard advice about water pump divider plates, and work had to be re done.....
The good ones are always willing to LEARN, or look at options.
Old 04-25-2021, 07:50 PM
jhein's Avatar
Actually, the guy that's doing the work for me seems very good and so far, I trust him. If I didn't. I wouldn't let him touch the car. He's been doing this for a long time here and he has a shop that he uses for rear ends. If he/they screw it up he'll either stand behind his work or never see me again. But so far I have a good feeling about it.
