Old 05-06-2021, 06:45 PM
Steve Shively Steve Shively is offline
Default Wiring for reverse light switch
On which wiring harness does the pigtail connecting wire from transmission switch for backup light connect to?
Old 05-06-2021, 06:52 PM
leeklm's Avatar
leeklm leeklm is offline
You should see a flat connector under the dash with one light and one dark green wire. One of those wires should be hot with key on, and the other leads to your backup lights. Run two wires connecting those green wires to your transmission switch. 99% sure I have the colors right for the late 60s and early 70s cars I have worked on.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
