Tri Power fuel pressure
What is the correct fuel pressure for the rochester center carb on a 65 setup?
Thanks Greg |
5.5 psi is a good pressure to run on all three carbs.
Higher pressure pumps do nothing for you if you do not have the correct fuel inlets, correct fuel line size from the tank, and a fuel tank pick-up that does not allow the fuel to run away from the pick-up. Tom V.
