70 LeMans Grill Colors?
What was the original coloring on a 70 Tempest/LeMans grill?
All black? Black egg crates, silver surrounds? Black egg crates, silver front on egg crates, silver surrounds? Photos would obviously help. Thanks, Mike |
The whole grille is silver argent. No blackouts
The best ones I have are apparently painted black. Any easy way to strip them without damaging the part? Is there such a thing as "plastic-safe" stripper? |
I actually glass-bead blasted some grills many years ago, and that worked very well. But be careful if you do the same. Try on a small, inconspicuous area first.
Others may have other ideas, but that did work for me. Hope that helps.
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
Thank you.
It would help if that were an option for me but I don't have a blast cabinet. Hopefully the oven cleaner will work and if not, I can think about glass beads or walnut shells. Mike |
I blacked mine out= really looks good with the silver
When I repainted my 71 grilles, I used a cheap soda blaster from Harbor Freight to blast them, then repaint them argent silver. It does not have a cabinet and did not damage the grilles.
The Following User Says Thank You to CraigGT37 For This Useful Post: | ||
Yes, I agree, looks great!
There are many painted black when you search photos online. |
If I can't get it done with oven cleaner, that sounds like a plan. I do have a cheap blaster that I used with slag but I had a place to do it back then. I guess soda will disappear and be less messy than walnuts. And no chance for it to be trapped and cause rust later on the grills. |
I had a good day... found some good grills I tucked away and forgot so the work just evaporated !!
A mind is a terrible thing to waste. Here's a black one I was going to strip. It was on the car when I bought it. It has some damage in addition to being ugly: Here's a better one that I could refinish without much work: And here's the best one, even has all mounting tabs intact and paint is good enough for me: This never happens. Then it did. And I like it. Mike |
