Old 06-09-2021, 10:22 PM
vertigto's Avatar
vertigto vertigto is offline
Default Heat Shield on RA Manifold?
On my 1970 GTO driver's side log manifold, there was a heat shield with riser tube to the air cleaner (see pic).
I purchased RARE oversized manifolds to replace the stock logs. Do ram air manifolds use a shield? If so, does someone make one that fits or will the stock one work? Also...how necessary?
Old 06-09-2021, 10:27 PM
vertigto's Avatar
I think I found my answer...from OPGI. Of course, backordered until August.
Heat Shroud, 1968-70 GTO Ram Air, D-Port
*Edit...looks like Ames has it too.
Old 06-09-2021, 10:51 PM
burd's Avatar
burd burd is offline
Barry makes those for everyone. Call him.
Old 06-10-2021, 07:47 AM
vertigto's Avatar
Apologies...Barry who?
I guess the main question is the necessity of using this on the new motor with the new RARE manifolds. Obviously wouldn't be used if I had went the header route. Would also mean backing out the 2 ARP bolts already installed for mounting (and if anytime I wanted/needed to get at the manifolds).
How many of the guys using the RARE manifolds opted to buy/install these? I am assuming the only purpose is to preheat air and route to the air cleaner for emissions purposes? No perceived performance or functionality gain?
Old 06-10-2021, 08:59 AM
Big Bear's Avatar
Big Bear Big Bear is offline
www.ebay.com › str › sonicmotors2010
Old 06-10-2021, 01:32 PM
Scott Thelander's Avatar
"" Heat Shroud, 1968-70 GTO Ram Air, D-Port""
another misled quote by the repoppers
68 HO yes,, 68 ram air no ....
and they fit OVER the head bolt on the threaded stud and held on with a locking castle nut
Old 06-10-2021, 01:56 PM
vertigto's Avatar
This would be on a '70 with the oversized RARE (2.5") reproductions.
Any issue with fitment on those?
Old 06-10-2021, 05:10 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
those manifolds are only oversized in the ID;
IIRC they have a bit more meat at the pipe connector too - otherwise they are dimensionally identical to originals.
1970 Formula 400
Old 06-10-2021, 07:54 PM
Big Bear's Avatar
Sorry link didnt work . Barry's business is Sonic Motors. Check his e-bay store there is one listed or google and call him.
Old 06-11-2021, 02:17 PM
promptcritical promptcritical is offline
I have them on my 72 HO motor with RARE manifolds. They fit the manifolds fine. I don't let the hot air get to my air cleaner though. I put them on because I want to motor to look stock on the outside.
Old 06-11-2021, 07:09 PM
burd's Avatar
Pick one up at the natz in Ohio in august. Barry’s usually there.
