Any thread links for:
Plastic Valance pan application/misc parts/assembly 1970/71/72/73 Front Fender ID #s and ID of differences |
http://www.forums.maxperformanceinc....d.php?t=730042 Buried post... http://www.forums.maxperformanceinc.....php?p=3331725 Last edited by Held for Ransom; 09-21-2015 at 05:12 PM. |
Long List of Tech Thread Archives on Pontiac Street thread
Here http://forums.maxperformanceinc.com/...d.php?t=644938 Quote:
adding the 455HO thread
http://forums.maxperformanceinc.com/...d.php?t=538654 I will combine it all in a week or so , and have you all look at it
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
Here is a link to an outside thread (if you allow them) on Honeycomb Wheel Restoration:
http://www.goatsgarage.com/huny2.html |
adding "Das Boot" bolt thread
http://forums.maxperformanceinc.com/...d.php?t=489495
One thing I would like to see but not sure if it exists is a complete part no. List for S.D. 455 both 73 and 74. I have found it hard sourcing parts as I don't always know correct parts for a 73 and 74. Right now I am stuck on timing cover, water pump and valley pan part #'s but a detailed guide would be great.
While this isn't the now sticky 'SD" thread, I would recommend you use a GM parts manual, go to the Illustration section to find the group number, then go back to the number section, find your group number and look for your part/year with the number,
>>Timing cover is # 482893 this number replaced #9796345 after '69, early '70 as supplies dwindled. >>Water Pump is # 488377 this number replaced #9790522 after 1969-70 as supplies dwindled. >> Cover, Valve push Rod ( valley pan) # 489823 ( '73-76) None of these parts are unique to a SD engine as far as I can see, which makes sense as it was a production engine and cost was a factor. PARTS Manual on a THUMB Drive ( USB)( '67-75) is here>> http://www.ebay.com/itm/1967-75-GM-P...item2c72fe4ae1 IF they dont ship outside the USA, let me know, Ill buy it and ship it down under, and you can refund me..
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 10-03-2015 at 02:06 PM. |
Thanks for your help formulabruce. I do have a us address I can use so thankyou for the offer also.
I have struggled getting the part numbers for these but you have cleared it up for me. Michael |
Endura Nose refinishing> http://forums.maxperformanceinc.com/...a+build+primer
adding this clip link for bumper mount , will edit
http://forums.maxperformanceinc.com/...d.php?t=780992
I feel your pain!
This has to stick
Can we change the word "Treads" to "Threads"? This is a great idea and everyone's work is greatly appreciated. This will be a great resource.
Go Cubs. Quote:
Benwheelbob I sent you a PM about your Makita buffer kit...go Jays
Done, also fixed a few links that did not work.
ANDRE 1972 TRANS AM , UNDER RESTORATION http://forums.maxperformanceinc.com/...d.php?t=656067 1972 FIREBIRD FUTUR PROJECT http://forums.maxperformanceinc.com/...d.php?t=674551 1978 TRANS AM (PARTS CAR) MAYBE 1971 LEMANS T37 (PARTED OUT) 1976 TRANS AM (PARTED OUT) 1984 6000LE (SOLD) 2003 SILVERADO 1500 |
#38
Added a link in the 70 threads
ANDRE 1972 TRANS AM , UNDER RESTORATION http://forums.maxperformanceinc.com/...d.php?t=656067 1972 FIREBIRD FUTUR PROJECT http://forums.maxperformanceinc.com/...d.php?t=674551 1978 TRANS AM (PARTS CAR) MAYBE 1971 LEMANS T37 (PARTED OUT) 1976 TRANS AM (PARTED OUT) 1984 6000LE (SOLD) 2003 SILVERADO 1500 Last edited by 72TAMAN; 10-17-2015 at 08:56 PM. |
#39
70 RESTORATION THREADS
http://forums.maxperformanceinc.com/...d.php?t=650016 71 RESTORATION THREADS http://forums.maxperformanceinc.com/...ght=heat+riser http://forums.maxperformanceinc.com/...d.php?t=608187 72 RESTORATION THREADS http://forums.maxperformanceinc.com/...ghlight=keepat http://forums.maxperformanceinc.com/...d.php?t=494143 http://forums.maxperformanceinc.com/...ghlight=keepat http://forums.maxperformanceinc.com/...=keepat&page=7 73 RESTORATION THREADS 70 THREADS http://forums.maxperformanceinc.com/...highlight=1970 http://forums.maxperformanceinc.com/...d.php?t=770380 71 THREADS 72 THREADS http://forums.maxperformanceinc.com/...highlight=1972 http://forums.maxperformanceinc.com/...d.php?t=736820 http://forums.maxperformanceinc.com/...ght=heat+riser https://www.youtube.com/watch?v=MNBk...ature=youtu.be 73 THREADS COWL TAG DECODING SITE http://www.78ta.com/cowl.php DECALS THREADS http://forums.maxperformanceinc.com/...highlight=1973 BOOK THREADS http://www.amazon.com/Trans-Am-Fireb.../dp/1613251726 REAR BUMPER THREADS FRONT BUMPER THREADS http://forums.maxperformanceinc.com/...d.php?t=780992 http://forums.maxperformanceinc.com/...a+build+primer SUB FRAME THREADS http://forums.maxperformanceinc.com/...d.php?t=489495 SUSPENSION THREADS http://forums.maxperformanceinc.com/...ghlight=keepat https://www.eatondetroitspring.com/o.../parts-lookup/ WHEEL RESTO THREADS http://www.goatsgarage.com/huny2.html http://www.forums.maxperformanceinc....d.php?t=554851 WHEEL CODE THREADS http://forums.maxperformanceinc.com/...d.php?t=583466 http://www.tran-zam.com/1971/Wheels.html http://www.pontiacserver.com/wheels.html http://www.wallaceracing.com/rally-wheel-date-code.htm 455HO THREADS http://forums.maxperformanceinc.com/...d.php?t=538654 SD THREADS http://forums.maxperformanceinc.com/...d.php?t=736345 http://www.angelfire.com/mi/jamos1/howto.html http://forums.maxperformanceinc.com/...d.php?t=496240 HOW TO REBUILD PONTIAC V8 MOTOR THREADS http://forums.maxperformanceinc.com/...d.php?t=623671 PONTIAC HEAD THREADS http://forums.maxperformanceinc.com/...d.php?t=636024 http://forums.maxperformanceinc.com/...d.php?t=636309 http://forums.maxperformanceinc.com/...d.php?t=534326 http://forums.maxperformanceinc.com/...d.php?t=585395 http://www.wallaceracing.com/head1.htm EXHAUST THREADS http://forums.maxperformanceinc.com/...d.php?t=468168 http://forums.maxperformanceinc.com/...d.php?t=550283 http://forums.maxperformanceinc.com/...d.php?t=630943 http://www.wallaceracing.com/exhaust1.htm TRANSMISSION THREADS http://forums.maxperformanceinc.com/...d.php?t=466818 http://forums.maxperformanceinc.com/...d.php?t=466820 http://forums.maxperformanceinc.com/...d.php?t=466821 BRAKE THREADS http://forums.maxperformanceinc.com/...d.php?t=593740 DISTRIBUTOR THREADS http://forums.maxperformanceinc.com/...d.php?t=652883 http://forums.maxperformanceinc.com/...d.php?t=530812 http://forums.maxperformanceinc.com/...d.php?t=479239 http://forums.maxperformanceinc.com/....php?p=5405995 MOTOR THREADS http://forums.maxperformanceinc.com/...d.php?t=690512 http://forums.maxperformanceinc.com/...d.php?t=609229 http://forums.maxperformanceinc.com/...d.php?t=769185 http://forums.maxperformanceinc.com/...d.php?t=772995 http://forums.maxperformanceinc.com/...d.php?t=739781 http://forums.maxperformanceinc.com/...d.php?t=730569 http://forums.maxperformanceinc.com/...d.php?t=772223 http://forums.maxperformanceinc.com/...d.php?t=776003 http://forums.maxperformanceinc.com/...d.php?t=379985 http://forums.maxperformanceinc.com/...d.php?t=583733 http://forums.maxperformanceinc.com/...d.php?t=579525 http://forums.maxperformanceinc.com/...d.php?t=593983 http://forums.maxperformanceinc.com/...d.php?t=556933 ENGINE CODES THREADS http://www.wallaceracing.com/engine1.htm FUEL SYSTEM THREADS http://forums.maxperformanceinc.com/...d.php?t=779232 CARBURATOR RESTORATION THREADS http://www.vintagemusclecarparts.com/ MISC WHEEL THREADS http://forums.maxperformanceinc.com/...d.php?t=748138 CAM THREADS http://forums.maxperformanceinc.com/...d.php?t=765522 http://forums.maxperformanceinc.com/...d.php?t=770467 SHEET METAL AND BODY THREADS http://forums.maxperformanceinc.com/...d.php?t=773122 http://www.forums.maxperformanceinc....d.php?t=528624 http://www.forums.maxperformanceinc....d.php?t=750558 http://forums.maxperformanceinc.com/...30#post5466030 PLASTIC VALANCE THREADS http://www.forums.maxperformanceinc....d.php?t=730042 http://www.forums.maxperformanceinc.....php?p=3331725 DASH THREADS http://www.78ta.com/resto/rdash.php INTERIOR THREADS http://www.buickperformanceclub.com/...lumnwobble.htm http://forums.maxperformanceinc.com/...d.php?t=514465 http://forums.maxperformanceinc.com/...ding+seat+belt http://forums.maxperformanceinc.com/...d.php?t=781255 JACK AND SPARE THREADS http://forums.maxperformanceinc.com/...d.php?t=780059 70 PARTS ONLY THREADS http://forums.maxperformanceinc.com/...d.php?t=580525 DEALER CODES THREADS http://forums.maxperformanceinc.com/...d.php?t=534976 73 TRANS AM UNIQUE FEATURES THREADS http://forums.maxperformanceinc.com/...d.php?t=449356 PLATING COMPANY THREADS http://www.paulschrome.com/ http://www.tricityplating.com/ VYNIL REPAIRS THREADS http://www.drvinyl.com/ OUR 70-73 PARTS GUY NORWOOD http://forums.maxperformanceinc.com/...r.php?u=141593
ANDRE 1972 TRANS AM , UNDER RESTORATION http://forums.maxperformanceinc.com/...d.php?t=656067 1972 FIREBIRD FUTUR PROJECT http://forums.maxperformanceinc.com/...d.php?t=674551 1978 TRANS AM (PARTS CAR) MAYBE 1971 LEMANS T37 (PARTED OUT) 1976 TRANS AM (PARTED OUT) 1984 6000LE (SOLD) 2003 SILVERADO 1500 Last edited by 72TAMAN; 10-17-2015 at 10:19 PM. |
#40
Thanks 72TAman.. this is coming along well
Thread Tools | |
Display Modes | |
