I HAVE A TRIPOWER SETUP. INTAKE CAST # IS 978818.I KNOW IT IS PRE-66 AS IT HAS SMALL CENTER CARB. IS IT BIG CAR OR GTO? THANKS
try this www.wallaceracing.com
some times when you race with squirrels you get your nuts cracked! |
I think when you posted you left one 7 out of the casting number. Casting number 9778818 is the 1965 tri-power, small base Rochester carb in the center. For GTO and big cars, same number.
[ March 06, 2002: Message edited by: Robert Williams ]</p>
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
Can you send me a Pix?
the later 65 Tri-power has the same bolt pattern as the 65-79 Pontiac heads. If so it is a 65. If it has the early bolt pattern and the long ears on the intake it is a 64. [img]/infopop/emoticons/icon_wink.gif[/img]
Try calling CRUSHPROOF! 512-386-9889 |
