i never had a 3 prong one, used the 5 prong later style on 3 engines that didnt leak... but that older 3 prong one was terrible & not even a professional shop could make it seal, their attempt leaked twice as bad as my initial attempt. finally found the cork gasket procedure & its worked great.
mine didnt split it actually rolled the bead & leaked, looked like a rear main seal leak since it was way up there by the rear main, took awhile to identify it. the shop actually tried replacing the rear main too when it wasnt the problem.
You can usually clean it off with brake cleaner and jack the front of the car up nice and high to find it. If ya run it, it gets all over.
yep i dis clean it off after the shop replaced it & the rear main but still leaked. i was able to confirm it was the rear pan gasket leaking & the cork gasket & ultra black sealed it up great.
RTV is used all the time on gaskets in various applications. I've personally used Ultra Blue on water pump and timing chain gaskets and Ultra Copper on exhaust manifold gaskets. Great stuff and never an issue!! Stuff says flexible which is a real plus!! To each his own!!! |
The Following User Says Thank You to Ram Air IV Jack For This Useful Post: | ||
I thought Indian Head shellac was required.
Sent from my iPhone using Tapatalk Pro |
I use Ultra Blue at home and work for Big vacuum pumps and roots style blowers.
Seems like a GM service tech told me it was oxygen sensor safe? One thing I always do is take a flat bastard file to ever flat surface, if it is flat it won't hurt a thing. Little burs are slight warpage from years over tightening can be filed back smooth with no problem. I do use ultra black often seems to work just as good. |
...And then I started using REAL gasket sealer, and saw how much better it worked. The gaskets don't squeeze out when the fasteners are tightened, the cleanup when the gaskets are replaced later is easier. And you don't have blue--red--copper--black shiit oozing out from around all the gasketed joints. I see a lot of gaskets stuck down with "Yellow Death", typically 3M Weatherstrip Adhesive but there's other brands of the same stuff, and some guys use "Black Death", same thing, different color. I'll never use that stuff on a gasket again, either. Sticks the gasket really nice. Cleanup the next time is a total bitch. |
I just replaced mine with this new style gasket. Works great, no messy sealer needed.
The Following 2 Users Say Thank You to 69ARROWHEAD For This Useful Post: | ||
Which Hylomar product are folks using?
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
I wish more of these types of modern gaskets were available for vintage stuff. They work tremendously. A bit pricey, but often can be used again and again. Reminds me of modern motorcycle gaskets ... they just plain don't leak. It's a safety issue on a bike, not to mention the exposed engines don't market well if they are covered in leaks.
That is for Chevy , similar but not proper . Most use the Chevy gasket & cry about leaks , use the proper Pontiac gasket & have no leaks.
Does the original Pontiac thermostat gasket have regular bolt holes not the elongated style?
& another option for t-stat housings if you dont care about originality is the aftermarket rubber O-ring housings. some may frown on them but i am using 2 of them on my cars with no issues & have reused them multiple times, zero leaks. very easy when you need to remove them & no clean up.
one is in use for over 10 years & the other has been removed at least 5 times in the last 5-6 years for different reasons. i originally used one back in the 90's for 10+ years on a 455. & if by chance they start to leak, you just buy a new $2 O-ring. surface does need to be smooth & no pitting though for a good seal. as for the gaskets squeezing out with RTV thing, when used as a dressing & follow the directions on the tube, i have never had a gasket squeeze out or move at all. the ultra black/grey says to tighten the bolts only snug then let sit for an hour or so to set up... then torque to spec. no movement & very hard to see anything oozing out if you use the right amount. & on a pontiac blue engine you dont really see the blue stuff, or in my case on a black with aluminum parts engine you dont see the black or grey. |
yes regular bolt holes, at least for 70's housings.
Yes the original style does not have elongated bolt holes & is available aftermarket.
#38
I just bought a CSR swivel t-stat housing and it came with an o-ring. I just used that and it's leak free. Prior to that, ultra grey or blue was my weapon of choice.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
