Old 10-12-2021, 12:32 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Default New 11-bolt water pump on the block at JEGS
Can't say I've seen this one, yet: https://www.jegs.com/i/JEGS/555/5108...kaAgcwEALw_wcB
Says it's a new product, that impeller looks pretty nice, and I like how they cast a twisted look the housing casting to differentiate it.
I just put a brand new Flowkooler 11-bolt on my car, so who wants to give this new thing a shot??
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Old 10-12-2021, 12:03 PM
turbo69bird's Avatar
I don’t get the whole twisted look idea doesn’t seem to add anything Don’t know it has any cooling benefit over the milodon or others
I am happy to see the aftermarket supporting Pontiac’s though.
So many other oarts we need more though than duplicates.
Like a proper 69 bird license plate bracket.
960 HP @ 11 psi, 9.70 at 146.
Old 10-12-2021, 12:28 PM
Sirrotica's Avatar
Thanks for the heads up, good information to know...........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-22-2021, 01:33 PM
I recently installed this new Jegs pump.
Aluminum body, composite, (plastic), impeller.
Came with two gaskets and a new plate. Has two sets of pulley attach holes, one for Pontiac and the other for Chevy (I guess).
No issues installing it. I did the usual plate clearance mod, cools fine
ID:	578377   Click image for larger version
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following User Says Thank You to Singleton For This Useful Post:
Old 11-22-2021, 04:05 PM
Thanks so much for posting and letting us know! Looks like a nice pump. How was the clearance initially with the included plate?
And a composite impeller, huh? That's interesting. That's one way to prevent corrosion, and most OEM impellers on modern cars are actually plastic/composite... that's definitely a first for Pontiac water pump options, though.
Old 11-22-2021, 05:24 PM
ZeGermanHam's Avatar
Not all parts are created equal, but after all the years of problems that BMW experienced with using composite impellers in water pumps, I personally would steer clear of any water pump that doesn't use a metal impeller. The composite impellers can crack and sheer off from the shaft, leaving you without coolant flow and an engine that's going to overheat. It was a major debacle for BMW, which is the other automotive universe I'm involved with. This is of course a different design, but composites become brittle with age and heat. Given this is an $84 product presumably manufactured in China, one has to wonder how it will hold up. Time will tell.
1998 BMW 328is (track rat)
Old 11-22-2021, 05:55 PM
Thanks so much for posting and letting us know! Looks like a nice pump. How was the clearance initially with the included plate? .
Didn’t measure it, but it was probably .080-.100 clearance initially
