Old 10-18-2021, 08:18 PM
neasb neasb is offline
Default Replacing inner tie rods -65 GTO
Due to clearance issues when greasing I plan to replace my inner tie rods with ones with the grease fitting on the end. My current ones have the fitting on side, which is a PIA to grease. Is it general practice to replace both inner and outer at same time, or am I ok with just doing the inners?
Old 10-18-2021, 11:15 PM
Unless the car is in a wreck, hits some major road damage etc. the hard parts typically aren't the concern, it's the joints. I would inspect the entirety of the steering linkage for worn joints, slop etc. If it's all in good shape, you can certainly replace only the inner tie-rods.
You may find however if it's stock equipment, that a total steering rebuild might benefit how the car drives.
-Jason
1969 Pontiac Firebird
Old 10-19-2021, 09:16 AM
Thanks JLMounce. The rest of my suspension is in good shape, so I’ll just install the inners, so my grease fittings are in a more accessible location.
Old 10-19-2021, 12:42 PM
Instead of replacing good parts just replace the fitting(s) with 90 degree one(s).
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 10-19-2021, 03:46 PM
Tried the 90, it hits the frame.
Old 10-19-2021, 03:50 PM
Per the Ames catalog, the originals had the fitting on the end, so mine are incorrect. Had the car 30 years and still learning stuff!
Old 10-19-2021, 04:01 PM
jamesq's Avatar
jamesq jamesq is offline
I bought a box of zerks from Ebay , the 45 degree might work,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
