Help the guy out, he does not want to listen to me. Guys with iron D ports are kicking his and my a$$. My stock block High Port engine will be a badd azz engine. How much power did yours make ? BTW, Edelbrocks new E head help make that decision. Wish I had a set. |
I would keep the Jones Cam. But put it back in at 110. Try the longer rockers after you get it back together. I agree with the others here on possibly having port work done. I would definetly have the valves spring pressures checked while the heads are off. Your statement about shifting at 6000 to 6500 with no change in ET makes me wonder if they are strong enough. I had similar results with a set of weak springs. My car never "laid over" or fell off on the top end but when i finally checked the springs they were weak. New spring and I picked up 2 mph.
Which new E-head are you talking about? ...... Right now they don't have much for our Pontiacs and most other makes. I have several sets of heads and a few manifolds on B.O. I was originally told April 6 and now being told the middle of May. |
Also, what is Your fuel system? I would pull the line from the carb, run the pump through the regulator into a 5 gal gas can. Run it for 1 minute to check how much gas it pumps. General rule is a motor needs 1/2 lb (weight) of fuel per HP per Hour.. So a 600 HP motor will need 300 lbs by weight of fuel per hour. 1 pound of gas weighs 6.5 lbs. So using this formula Run the pump through the regulator for 1 minute. If it pumps 2 gallons of gas that shoukd be enough to support 780 HP. ( 2gal. X 6.5lbs X 60minutes)
Now, how much power does your bad boy High Port stock block engine make ? CR ? |
Something about that does not seem.............right.
Are you saying you can no longer put a valve bigger than 2.19" in the heads or they got cheap and are using a smaller seat ring? So that now you need to replace the seat ring to install a valve larger than 2.19". Stan
From my understanding the od of the seat now now smaller and 2.19 is biggest valve that'll fit
Besides, hard to believe the 2 people I know of who have 2.25 intakes on new CNC E heads are making it up. |
I hope im wrong. Would love to hear first hand experience
You can look at the pics, the seats in the old style chamber sure seem to butt up against another more than the newer style chamber. Looks to me like seat od was decreased on new head.
The original style bathtub chamber is the better choice for a max-effort deal.
So in other words I should sell my HP's and get some Edelbrocks. I should have sent my old Eheads to Paul K. Like I was originally planning. If I could afford it I would just build a 505 or 535. But not in the budget.
Scott S. My fuel system is an Aeromotive 150 SS pump through a 1/2 inch line to an Aeromotive dead head regulator that splits into two -6 lines to the carb. Also, my valve springs are Hiwards 1.625 OD and they probably don't even have a 100 miles on them and a handful of 1/4 mile passes. I checked them with an on head checker and they were che king around 220 on the seat. Thanjs fir your help. |
Stan
#38
Thanks Paul K. I think that's what I'm just going to do. My brother has a Victor he's not using.
Stan, no I have not yet. |
The Following User Says Thank You to BLANK1 For This Useful Post: | ||
#39
These were my best times at the Pontiac Nats. Car #972. Still not impressed even with the changes. Dont know what happened to my 60 fts. Maybe its the Viking DA shocks. 60 footed better with my old comp 3 ways. MPH still not that much better. Basically still running the same. Car race weight was 3875. How do I get this thing to run low 10's without resorting to nitrous? Tired of putting money and time in it and getting no where. I know I need more track time. But most tracks are two hours away and they just bracket race. Drive all that way for a couple runs not worth it.
#40
As you can see in the 2 slips,your getting killed in the 60ft.Chassis work looks like required.Tom
