Old 09-28-2021, 06:02 PM
What's the 60' like?
Spinning?
Or lazy?
Bogging?
Front coming up a lot or not at all?
What launch RPM?
  #42
Old 09-29-2021, 07:34 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
Felt lazy. Checked pinion angle when I got home and it'was at less than -1 . I have set it at - 3 now. Haven't made it back to the track yet. Dont know how much the pinion angle affects the launch.
  #43
Old 09-29-2021, 10:37 PM
blueghoast's Avatar
blueghoast blueghoast is online now
A hole lot.
Have you tryed shifting less than 6000 1st to 2nd?
GT
  #44
Old 09-29-2021, 11:23 PM
BLANK1's Avatar
Blueghoast, no I haven't tried under 6.
  #45
Old 09-30-2021, 08:38 AM
aaronman aaronman is offline
From your Norwalk time slip you are two tenths slower in the 60’ by comparison to Bill Meyer (m591) in the other lane but almost equal mph. The good news is you are making good power. Now you need to translate that to your 60’. Usually starting line ratio and converter changes will be required to optimize your combination.
  #46
Old 09-30-2021, 08:50 AM
grandville455's Avatar
grandville455 grandville455 is offline
Something is off, U are not making any mph to the 1/8th!! Have u verified fuel, timing etc.. what's the conv flash too? Where's it drop on the shift?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #47
Old 09-30-2021, 12:05 PM
pastry_chef's Avatar
Agree.
Darby, your previous Jones cam was pretty similar to this?
Jones solid roller 4/7 swap. 316/320 adv. 263/269 @ .050 on a 110 LSA installed at 106 ICL, .421/.412 lobes. Using 1.6 rockers
Did you break 9's with it?
  #48
Old 09-30-2021, 03:11 PM
Originally Posted by pastry_chef View Post
Agree.
Yes my jones was 265/270 110 set at 106 i believe, mine didn't have the 4/7 swap
Yes went 9.97@132ish, in like 1300 da? also went 9.95@134 in better weather and tailwind
Darby
  #49
Old 09-30-2021, 03:16 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Braggert!
Go fast, see Elvis!
