1969 GTO Power Seat Not Working
Well the fact that there's even a power seat in the car seems pretty cool. It will spin the belt in the front but it won't do anything.
I would assume that the relay works along with the switch and potentially the transmission inside, so it's maybe the ???? Also, I have 3 seat belts that have normal bolts holding them down. This 4th one is a stud and nut??? I was gonna swap to chrome bolts through OPGI but I wanna make sure first.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
my sugestion is pull the seat track
The 68 Fisher Body manual has a ton of info on power seats if you have one.
