Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Wanted: New Old Stock GM 066 Camshaft
Looking for a factory 066 camshaft hopefully that’s new old stock. Any leads are appreciated. Thanks, Jim. Wake Forest, NC
The Sealed Power CS641 cam is purported to be the same grind as the factory 066 cam. The CS641 is available on eBay, Rock Auto, etc
If it ain't broke, fix it 'till it is |
He’s searching for old GM factory stock, nothing new that’s readily available.
The Following 2 Users Say Thank You to b-man For This Useful Post: | ||
Found an older (at least 17 yrs old) NOS Elgin cam that’s the 066 duplicate. Now lifters. I assume Hy-Lift Johnson are the only USA made lifters available.
I'd think other brands are available. Hylift-Johnson is THE best lifter made, not cheap.
Its the only brand I would use.
Bart, What lifters did you use with your O.E. 068 cam?
the smaller grind do pop up from time to time on ePay;
I think there's a '555 on there right now, and I am fairly confident that I have seen 066 in the past.
Now looking for some NOS Pontiac or pre offshore lifters.
