Old 01-20-2021, 01:09 AM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
I will get that block number in the next few days. also to shermanator2
Im glad that the head you got was a better match and worked out.
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
  #102
Old 01-23-2021, 02:41 AM
JKrull66's Avatar
Originally Posted by unruhjonny View Post
I just noticed this and figured I'd reply:
If my numbering is correct, G309 would be July 30th 1969;
Since July was the last month of the production year, and I have understood that the last of the prior model years cars would be produced early in the month of July, it stands to reason that something cast on the second last day of July would probably be used for something produced for the following model year.
I think it is common to see items cast in August as being for the new model year, and if my memory serves me, it seems to be quite rare for anything cast after June to be used for that same model year.
I would guess that in this case, we could conclude that when that block was cast (on July 30th 1969), the "70" was there to indicate that it was being cast for the 1970 model year.
Was that block cast with the '914 casting number?
yes it is a 914.
66 GTO HT Cruiser
POLARIS 900 RZR
  #103
Old 01-23-2021, 02:46 AM
JKrull66's Avatar
I seen a top end for sale dated F249 for a ram air 111 70 gto w 12 castings thought was interesting to add to mix.
66 GTO HT Cruiser
POLARIS 900 RZR
  #104
Old 01-23-2021, 07:09 AM
steve25 steve25 is online now
To me the lock in in terms of what that late cast block is for would be if it had 4 motor mount pads that are drilled, or the 5 drilled pads needed for 1970 car needs.
  #105
Old 01-25-2021, 06:00 PM
69gtocv 69gtocv is offline
They were already using the "70" cast 914 block as early as mid June. My 69 Baltimore built Gto convertibles block was a 914 and was dated F199 (or F239, I don't own the car any longer to confirm).
  #106
Old 01-25-2021, 06:44 PM
unruhjonny's Avatar
oh - cool!!
Your 1969 GTO must have been a very late build!!
That casting date is for a third or fourth week of June according to an online calendar I just glanced at.
June 19 = Thursday of the third week of June
June 23 = Monday of the fourth week of June
I know that there are "rules" about what is considered an appropriate window for a given build date;
I have it written that 3-8 weeks prior to the car's build date is average.
1970 Formula 400
  #107
Old 01-25-2021, 07:10 PM
oh - cool!!
Yup, it was a 6D build. All the original dated engine parts were still on it except for the carb and I think the "oldest" part on it was f139, so it had a tight window between foundary and build.
I remember being initially confused when I saw the 70 on the block, but relieved that the vin matched
  #108
Old 05-12-2022, 09:31 AM
rwfisher's Avatar
rwfisher rwfisher is offline
Quick add. May 12 69 48 heads off low mileage 400, never touched. Chamber volume checked before going off to machine shop. All chambers measured 68cc to 69cc. No X stamp noted. Didn’t get a chance to take measurements but valve recess appear to be minimal to none.
The Following 3 Users Say Thank You to rwfisher For This Useful Post:
  #109
Old 08-15-2022, 08:04 AM
mysticmissle's Avatar
adding for information, I cced a set of E1969 48 heads yesterday, replacement stainless valves, appear to have factory deck swirl, came in at 67cc
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
