Old 01-02-2020, 02:33 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Talking
Originally Posted by S/st 54 View Post
It will take some financial help if I were to put the Pontiac back in the car to run it at NHRA races.
You need to explain to him that you're trying to keep up with a certain Big Dog in the MPH department. My 150 MPH junk holds up just fine
Dave Polichena
Old 01-04-2020, 08:32 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
See you in Belle Rose?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 01-09-2020, 01:39 AM
69MaizBird 69MaizBird is offline
Lol I'm right there with you. But my 505 and my 535 give me plenty of time on the stop in s st. Its 11.5 here in Colorado div 5
I'm running the 535 under d ports this year and hoping it will go all season.
If I'm lucky that is 130 passes or so. I'll take it down for Inspection after that. We used it part of last year in some e t stuff.
I'm not playing with the big guys it's only pushing 850 at 2800# on race gas. I'm a slow bracket guy lol. Get to race more that way.
Keeping on topic, I would like to hear any experience s with a sniper on top of a stop.
Old 01-14-2020, 08:10 PM
cgeise's Avatar
cgeise cgeise is offline
I ran the sniper all last year it is super tunable and easy to do so -- just fyi I don't "whomp " the throttle --I ride the brake -- but I have no doubt it would work fine as I said -- its very responsive -- let me know if you have questions
Old 01-14-2020, 08:14 PM
cgeise's Avatar
Yes it has a self lean feature to get you close -- I use my ignition as a stand alone -- its a digital 7 and as I have a fair amount of experience I am real comfortable tuning the fuel map on this thing -- but with some time anyone can do it .
Old 01-14-2020, 09:11 PM
slowbird's Avatar
slowbird slowbird is online now
Curious if you have noticed an increase in mph from the switch?
Old 01-14-2020, 09:16 PM
cgeise's Avatar
yup --- was running an 1150 -- the sniper is about 2 mph faster
Old 08-16-2020, 10:02 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Hey Mike, you ever get the sniper installed? Results?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 05-15-2022, 07:42 AM
mysticmissle's Avatar
anyone have any updates on this system?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 05-15-2022, 03:38 PM
R 70 Judge's Avatar
I’d also be interested in updates
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 05-15-2022, 09:25 PM
cgeise's Avatar
been running it for over 2 years and we just put another one on 632 dragster -- easy peasy
Old 05-16-2022, 01:26 PM
Do you have to plot your curve for when on the stop or will the TP sensor take care of that?
Dave Polichena
Old 05-17-2022, 07:35 AM
grandville455's Avatar
What happens if this is used on a motor with only 800 hp? Injectors too big? trying to learn!
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 05-17-2022, 10:25 AM
Scott65's Avatar
Scott65 Scott65 is offline
Generally speaking, yes. The small pulsewidth area is where injectors become non linear, and harder to tune. Idle is where you get into trouble. Some ECU's are capable of fine tuning the small pulsewidth area if the injector data for that is known. This is why you sometimes see "staged injection". A smaller injector to drive/idle on, and bigger one to handle the horsepower. At these power levels, I'm not seeing the draw to tbi units. MPFI brings the ability to tune per cylinder, and stage injectors, handling all the areas the engine operates in better. And if you wanna go to E85 as was mentioned earlier, you can do that too, just different injectors, not a whole new, different tbi system.
Old 05-18-2022, 02:19 PM
cgeise's Avatar
you can probably fudge the HP down a bit by running reduced fuel pressure , and all the stuff for running a throttle stop is pretty easy by playing with your fuel map.
