Goofy Headlight Issue On 1972 Le Mans
Hi,
First, I would like to thank everybody for their help with my heater issue (on another thread). I appreciate it very much. Now, my old girl just started hitting me with a headlight issue: When I turn on the high beams, one of the low lamps goes out. When I turn the highs off, the low lamp goes back on. The other side functions normally. Has anybody seen this? Is it just a switch issue? Thank you! |
its a ground issue
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
The low beam has 2 filiments in it, when you turn the high beams on it goes to the high beam filiment in your low beam. The high beam filiment is burned out thats why the light goes out. You need to repleace the low beam on that side then it will come on, you don't have a ground problem. The high beam only has 1 filiment & is there for high beams only. Replace the bulb on that side & you'll be done.
yup, what rex said...burned out hi beam in your low lamp.
Pat Brown |
George |
