1972 Le Mans Front Coils
Hi,
This will be my first attempt at replacing the front coils on my '72 Le Mans 4-door. I was wondering if there are any pointers you may have before I start. From a more practical standpoint, I was wondering if anybody had a recommendation for a spring compressor (which I assume will be an exterior one). I don't have a transmission jack, so the official GM spring compressor tool is out. I appreciate your input! George |
Use an internal compressor, thru the upper shock hole. Lube the hell out of the compressor washers and threads.
I just did this task today. |
OK -- thank you! My biggest concern is having parts left over from the stabilizer assembly. lol
For my own piece of mind, I also slid a length of rebar down through the spring, just so if "something" happened the spring would at least stay put. I'd have a heart attack from the noise but the spring wouldn't knock my head off......
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
+1 on the internal compressor. I like to put strips of inner tube between the compressor hooks and the coil, it just helps stop the compressor hooks from rotating as you tighten the nut.
"GTO......Gas, Tires and Overdraft"! '70 GTO convertible, 434, 4-speed |
Thank you! Is there a compressor tool you recommend?
If you don't have one, I know a few of the local parts stores do rent them, might be an alternative to buying one.
Thread Tools | |
Display Modes | |
