Old 04-15-2022, 08:55 PM
rare4k's Avatar
rare4k rare4k is offline
Default Gas problems
Ok fresh rebuilt carb, new fuel pump, new lines, new tank, new sending unit, new gas cap, will not start on its own have to add gas to the carb, had the same problem before I had the carb rebuilt as well, at first I thought it was the acceleratior pump in the carb, after rebuild same problem any ideas?
Sent from my moto z3 using Tapatalk
Old 04-15-2022, 09:54 PM
tom s tom s is online now
I understand all new but did you blow air thru the fuel line at the engine back to the tank to confirm no restriction?Tom
Old 04-16-2022, 01:49 AM
rare4k's Avatar
I was going to to that today, that's the only thing I can think of as well, thanks Phil
Old 04-16-2022, 11:34 AM
bobslilgto's Avatar
bobslilgto bobslilgto is offline
Check the fuel pump acentric cam if nothing else works. I had a 67 G/P that gave me a lot of problems. The timing chain was changed at one time and the cam was installed incorrectly and the tab was in the wrong spot. Now I know why the car had low mileage and was a steel. Good luck! Bob
Old 04-16-2022, 11:48 AM
rare4k's Avatar
Bob, I would think that it would not work at all if in incorrect? This runs as long as you prime it.
Old 04-16-2022, 04:15 PM
bobslilgto's Avatar
My car ran and on hot days it would like vapor lock, but it was the cam because I did everything you did and still had the problem. I would not have found it if i didn't pull the motor to give it a refresh. I don't know how it ran but it did even on a 1 hour drive and never starved for gas.
Old 04-16-2022, 04:16 PM
bobslilgto's Avatar
The position of the cam made it work ever so slightly.
Old 04-16-2022, 05:07 PM
Does it do this even after it has been run? Like even the next day? I know I use to have that problem with ethanol fuel drying out after several days and a few of my vehicles I actually had to pour gas in carb to get going.
Old 04-16-2022, 06:34 PM
bobslilgto's Avatar
The only time I had a problem was when it got hot and then stall and wouldn't start until it cooled down a little. I always thought it was vapor lock and maybe it was with such low fuel pressure. Cold start was perfect.
Old 04-16-2022, 11:38 PM
rare4k's Avatar
Problem found, brand new line had a cut in it on top of the rear frame rail.
The Following User Says Thank You to rare4k For This Useful Post:
Old 04-17-2022, 09:10 AM
bobslilgto's Avatar
Good deal!
