Old 05-02-2022, 01:00 PM
RBAILEY RBAILEY is offline
Default 1st pass with new engine combo
My slicks did not arrive in time so I had to race with my street tires.
Naturally asperated through mufflers on street tires
Name:	10.17 134.15xx.jpg
The Following User Says Thank You to RBAILEY For This Useful Post:
Old 05-02-2022, 02:00 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice! That's strong MPH for the ET.
Old 05-02-2022, 02:54 PM
well..I had to race on street tires and unable to launch the car as it should be launched at a higher RPM...had to pedal it a bit but was surprised I got out as cleanly as I did. 1.55 60 ft. Correct me if I'm wrong but dont guys running 10 teens usually have a 60 in the 1.40 range?
Old 05-02-2022, 03:05 PM
Dragncar Dragncar is offline
Nice job, you get that thing hooked up and you will have 60 foots in the 1.3s.
My junk 60's in the 1.43-45 range and is not nearly as fast.
You have to have a big aftermarket block engine right ?
Old 05-02-2022, 03:47 PM
My car would 60' in the mid to low 1.40s went 6.38 @ 107. What street tires are you using? How big are the slicks you plan to use?
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 05-02-2022, 03:53 PM
Car not near me now so cant check exact model but I was running a 275 60r 15 full treaded Nitto street tire...the slicks that Im waiting on are Phoenix bias ply 28 X 9
Old 05-02-2022, 03:55 PM
No ...455 OEM block bored .060 ...cubes are 474. Car weighs 3300 WITHOUT my 200 pound butt in the car. Went 135.00 on the second and last pass
Old 05-02-2022, 04:47 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 10.30 pass at 132.50 I only has a 1.55 60 ft. Mine should be hitting harder.
Skip Fix
Old 05-02-2022, 04:53 PM
yup for sure.
Old 05-02-2022, 06:18 PM
slowbird's Avatar
slowbird slowbird is offline
Nice!!
Curious what the compression is?
Old 05-02-2022, 06:44 PM
Originally Posted by slowbird View Post
Nice!!
low 11:1 neighborhood
Drive to track on pump then switch straight 100 octane Sunoco once at the track. Paid 9.99 per gallon for the Sunoco 100
Old 05-02-2022, 06:55 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What is the combo?
Old 05-02-2022, 08:36 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Have you ever considered trying the combination on pump gas? What heads? Impressive street car.
Old 05-02-2022, 09:09 PM
R 70 Judge's Avatar
Nice passes. Especially for street tires
I’m curious of the combo as well. Cam specs if you care to divulge?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 05-03-2022, 12:47 AM
Originally Posted by ponjohn View Post
What is the combo?
474 CUBES
.060 OVER 455 BLOCK
4.250 stroke
375 cfm@750 Hi Ports - 74 cc chamber ..2.25 intake valve ...have flow chart showing up to 850 lift I think @ 385cfm
not sure exact compression....the software guy here (Stan Wiess I think) did an estimate for me...gotta find post ...I have not measured everything with a buret. but in mid 11:1 at highest I think
Comp Cams solid roller 760 lift installed at 104 w/ 108 separation
277 @ .050 both sides
T&D shaft rockers ...1.75
induction is Wenzler Gutsram with 2 660 center squirters ...manifold was a lot of work to get precisely port matched up ... but easy to see because of straight shot
mad dog round port headers with 3.5 inch exhaust and old 40 series flow masters from the early 90s
3300 pound gen 1 firebird less driver
3.73 gears
th400 w brake and anew Coan 10" thats supposed to flash to 5500 - did not get to test it without having the slicks though and had leave starting line at like 3 and then try to nurse it off the line. The trip to the track was only the 3rd time I drove since starting it one week prior and i did stall it up real quick on the brake and it easily went up to 4500 and I stopped cuz was still nervous about evrything.
Suspension is mostly stock but with all the good boltins ...caltrcs, split monos, 9 way single adjustablee rear Calverts and their fixed 90/10s up front
I'm lucky and live within 10 miles of a track. So far I love the converter; it drives like a normal converter and I'll know more when I can launch at max stall with slicks
The Following 3 Users Say Thank You to RBAILEY For This Useful Post:
Old 05-03-2022, 12:50 AM
not sure yet..all new to me...1st set of alluminum heads for me. But I do drive to track on pump without additive whereas before with my
iron dport motor I would use additive
Old 05-03-2022, 06:33 AM
chuckies76ta's Avatar
474 CUBES
.060 OVER 455 BLOCK
4.250 stroke
3.73 gears
That's very impressive times, especially with a 1.55 60 ft and a weight of 3500 pounds. 10.17 at 135 mph. Something is working real good. You've definitely have 9's in it when it hooks up. What are you spinning it too? track finish rpm.
Old 05-03-2022, 10:52 AM
Only made two full runs so not many chances to watch... pretty sure it was about 6800 as I tried to make a point to look on that 1st pass. More runs and I can answer that better.
Old 05-03-2022, 03:10 PM
474 CUBES
.060 OVER 455 BLOCK
4.250 stroke
3.73 gears
I like your combo. Who did your heads ?
You ride has some nice top end pull. I bet you have a 9.90-9.80 in that thing. Is the car legal under 10.00 ?
Old 05-04-2022, 08:33 AM
Half-Inch Stud's Avatar
10.01 is a great ET goal. What RPM does your engine reach doing the 10.1s?
